[postgis-devel] 1, dot, 3 dot 4!
Obe, Regina robe.dnd at cityofboston.gov
Fri Oct 17 01:00:37 PDT 2008
Paul,
I don't feel I've had enough time to test.  There was something a little odd I wanted to reinvestigate.
Can I have a day more still haven't taken everything thru the cycles.  I also installed on my new Open SUSE 11.0 VM and I'm getting a failure in one of the regression tests.  I don't think I had a failure in my 10.5 before but I just downloaded the latest 1.3.4SVN.tar.gz.  Can I safely ignore the kml test?
So here are my checks
 PostgreSQL 8.3.1 on i686-pc-linux-gnu, compiled by GCC gcc (SUSE Linux) 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision 135036]
 Postgis 1.3.4SVN - 2008-10-17 07:55:02
   GEOS: 3.1.0-CAPI-1.5.0
   PROJ: Rel. 4.6.0, 21 Dec 2007
Running tests
 loader/Point.............. ok
 loader/PointM.............. ok
 loader/PointZ.............. ok
 loader/MultiPoint.............. ok
 loader/MultiPointM.............. ok
 loader/MultiPointZ.............. ok
 loader/Arc.............. ok
 loader/ArcM.............. ok
 loader/ArcZ.......... ok
 loader/Polygon.............. ok
 loader/PolygonM.............. ok
 loader/PolygonZ.............. ok
 regress. ok
 regress_index. ok
 regress_index_nulls. ok
 lwgeom_regress. ok
 regress_lrs. ok
 removepoint. ok
 setpoint. ok
 simplify. ok
 snaptogrid. ok
 affine. ok
 wkt. ok
 measures. ok
 long_xact. ok
 ctors. ok
 sql-mm-serialize. ok
 sql-mm-circularstring. ok
 sql-mm-compoundcurve. ok
 sql-mm-curvepoly. ok
 sql-mm-general. ok
 sql-mm-multicurve. ok
 sql-mm-multisurface. ok
 geojson. ok
 regress_ogc. ok
 regress_bdpoly. ok
 regress_ogc_cover. ok
 regress_ogc_prep. ok
 regress_proj. ok
 kml. failed (diff expected obtained: /tmp/pgis_reg_21692/test_40_diff)
Run tests: 40
Failed: 1
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Mark Cave-Ayland
Sent: Fri 10/17/2008 3:11 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] 1, dot, 3 dot 4!
Paul Ramsey wrote:
> Let's get this release, out the door!
> Goooooo team!
> So, no howls of pain from testers... shall we release?
> P.
Just a couple of things:
i) I'm currently at EU PGDay in Italy, and so haven't had a chance to
test on my Windows build system. I'll have access to the testing
environment again late Sunday/early Monday.
ii) How will the release timing work with regard to GEOS? Since the
Windows installer won't change after release, if it goes now then I'll
build with the latest official GEOS release which is 3.0.1. So I guess
for the time being it will be no prepared geometry goodness for the
Windows masses.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081017/7efe488a/attachment.html>
