[postgis-devel] 1.3.4rc1
Greg Troxel gdt at ir.bbn.com
Mon Oct 20 07:35:06 PDT 2008
  The PostGIS team is pleased to provide release version 1.3.4rc1 for
  your testing delectation.
  You may download it from:
  http://postgis.refractions.net/download
I dropped that version into pkgsrc (but am not committing it), and built
against geos 3.0.2, proj 4.6.0, and pgql 8.1.14 on NetBSD/i386
4.0_STABLE.
The patch at the end of this mail is in pkgsrc to add dragonfly support
and it would be nice to apply it upstream, although I realize it is the
11th hour.
The rc1 tarball unpacked into postgis-1.3.4svn instead of the expected
postgis-1.3.4rc1.
I tried to run make check before installing postgis, and that failed
immediately, but README.postgis implies it should work.  After
installing, make check succeeded.  I do not understand how pre-install
make check could work, so perhaps this is just a documentation buglet.
patch:
$NetBSD: patch-aa,v 1.3 2006/12/06 17:43:27 joerg Exp $
--- lwgeom/Makefile.shlib.orig	2006-12-06 17:36:49.000000000 +0000
+++ lwgeom/Makefile.shlib
@@ -140,6 +140,10 @@ ifeq ($(PORTNAME), freebsd)
   endif
 endif
+ifeq ($(PORTNAME), dragonfly)
+  LINK.shared		= $(COMPILER) -shared -Wl,-x,-soname,$(soname)
+endif
 ifeq ($(PORTNAME), netbsd)
   ifdef ELF_SYSTEM
make test log with postgis not installed:
gdt 105 /usr/pkgsrc/geography/postgresql81-postgis > make test
=> Bootstrap dependency digest>=20010302: found digest-20080510
===> Testing for postgresql81-postgis-1.3.4rc1
Using GNU make found at /n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/.tools/bin/gmake
gmake[1]: Entering directory `/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/postgis-1.3.4svn'
/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/.tools/bin/gmake -C regress test
gmake[2]: Entering directory `/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/postgis-1.3.4svn/regress'
Creating spatial db postgis_reg
ERROR:  function postgis_lib_version() does not exist
HINT:  No function matches the given name and argument types. You may need to add explicit type casts.
 Something went wrong (no postgis installed in postgis_reg).
 For details, check /tmp/pgis_reg_15161/regress_log
gmake[2]: *** [test] Error 1
gmake[2]: Leaving directory `/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/postgis-1.3.4svn/regress'
gmake[1]: *** [check] Error 2
gmake[1]: Leaving directory `/n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis/work/postgis-1.3.4svn'
gmake: *** [check] Error 2
*** Error code 2
Stop.
make: stopped in /n0/gdt/NetBSD-current/pkgsrc/geography/postgresql81-postgis
*** Error code 1
Stop.
make: stopped in /usr/pkgsrc/geography/postgresql81-postgis
/tmp/pgis_reg_15161/regress_log:
CREATE DATABASE
BEGIN
psql:lwpostgis.sql:44: NOTICE:  type "histogram2d" is not yet defined
DETAIL:  Creating a shell type definition.
psql:lwpostgis.sql:44: ERROR:  could not access file "/usr/pkg/lib/liblwgeom": No such file or directory
psql:lwpostgis.sql:50: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:56: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:62: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:70: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:88: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:94: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:100: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:106: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:113: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:131: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:137: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:143: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:149: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:156: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:162: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:170: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:176: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:182: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:188: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:204: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:215: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:221: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:228: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:234: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:241: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:247: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:254: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:260: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:267: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:273: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:280: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:286: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:292: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:298: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:304: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:310: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:317: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:323: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:330: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:336: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:344: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:351: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:358: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:364: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:382: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:388: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:394: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:400: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:407: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:413: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:419: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:425: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:431: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:437: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:443: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:449: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:455: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:461: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:467: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:473: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:479: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:497: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:503: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:509: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:515: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:523: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:542: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:548: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:554: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:560: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:567: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:575: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:581: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:587: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:593: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:599: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:605: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:611: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:617: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:623: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:629: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:635: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:641: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:647: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:653: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:659: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:665: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:671: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:677: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:690: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:696: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:702: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:708: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:714: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:720: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:726: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:732: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:738: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:744: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:750: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:756: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:766: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:772: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:778: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:784: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:789: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:800: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:816: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:826: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:838: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:850: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:856: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:862: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:868: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:874: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:880: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:886: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:892: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:898: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:904: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:910: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:916: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:922: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:928: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:934: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:940: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:946: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:952: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:958: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:964: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:970: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:976: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:982: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:988: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:994: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1002: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1008: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1014: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1020: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1026: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1032: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1038: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1044: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1050: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1056: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1062: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1068: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1081: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1086: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1091: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1096: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1101: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1106: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1111: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1142: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1151: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1164: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1170: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1176: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1182: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1188: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1194: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1200: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1206: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1216: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1222: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1228: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1234: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1240: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1246: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1252: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1258: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1264: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1270: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1276: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1282: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1288: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1294: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1300: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1310: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1316: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1322: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1328: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1334: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1340: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1346: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1352: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1364: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1370: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1376: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1382: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1387: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1393: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1401: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1407: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1413: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1419: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1425: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1431: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1439: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1445: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1451: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1457: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1463: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1469: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1477: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1484: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1490: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1496: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1502: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1508: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1514: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1520: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1527: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1533: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1540: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1546: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1552: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1558: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1564: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1570: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1580: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1586: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1592: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1598: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1605: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1611: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1617: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1623: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1629: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1635: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1641: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1647: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1653: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1659: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1665: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1671: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1677: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1683: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1690: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1697: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1703: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1709: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1716: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1723: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1729: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1735: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1743: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1752: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1758: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1764: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1770: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1776: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1782: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1788: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1794: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1800: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1806: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1812: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1818: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1824: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1830: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1836: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1842: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1848: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1854: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1860: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1866: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1872: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1878: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1884: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1890: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1896: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1902: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1908: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1914: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1920: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1926: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1932: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1938: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1944: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1950: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1956: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1962: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1968: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1978: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1984: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1990: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:1996: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2002: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2008: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2014: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2020: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2026: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2032: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2038: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2044: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2050: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2056: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2062: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2068: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2074: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2080: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2086: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2092: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2098: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2104: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2110: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2116: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2122: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2128: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2136: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2144: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2150: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2156: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2162: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2168: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2174: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2180: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2186: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2192: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2198: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2204: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2212: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2220: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2223: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2229: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2235: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2241: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2247: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2260: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2266: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2273: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2280: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2286: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2292: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2299: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2306: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2319: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2325: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2334: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2340: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2357: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2368: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2378: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2384: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2393: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2399: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2407: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2412: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2420: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2425: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2445: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2462: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2482: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2498: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2509: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2527: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2543: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2652: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2746: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2923: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2941: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:2959: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3031: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3053: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3075: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3120: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3132: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3145: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3233: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3249: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3265: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3279: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3293: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3332: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3345: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3352: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3357: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3363: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3372: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3376: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3386: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3390: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3395: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3399: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3403: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3407: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3411: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3415: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3467: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3477: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3483: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3489: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3495: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3501: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3507: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3513: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3519: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3525: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3531: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3537: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3543: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3549: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3555: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3562: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3568: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3574: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3580: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3586: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3592: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3598: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3604: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3610: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3616: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3622: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3628: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3634: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3640: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3646: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3649: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3650: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3651: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3652: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3653: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3654: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3655: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3656: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3657: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3658: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3659: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3660: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3661: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3672: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3678: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3685: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3691: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3698: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3704: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3711: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3717: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3724: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3730: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3736: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3742: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3752: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3758: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3764: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3770: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3776: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3782: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3788: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3794: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3800: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3806: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3816: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3822: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3828: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3834: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3840: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3846: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3852: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3858: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3865: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3871: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3877: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3883: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3889: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3895: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3901: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3907: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3913: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3919: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3925: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3932: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3939: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3945: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3951: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3959: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3967: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3973: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3979: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3985: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3991: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:3997: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4003: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4009: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4015: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4022: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4028: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4034: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4040: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4046: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4053: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4058: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4064: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4071: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4077: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4083: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4090: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4096: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4102: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4109: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4115: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4121: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4127: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4134: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4141: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4147: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4154: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4160: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4167: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4173: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4179: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4185: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4191: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4197: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4203: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4209: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4215: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4221: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4227: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4233: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4239: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4249: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4255: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4261: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4267: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4273: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4279: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4288: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4295: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4301: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4308: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4314: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4321: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4328: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4337: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4344: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4350: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4357: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4364: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4370: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4377: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4384: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4394: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4400: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4406: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4412: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4418: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4424: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4430: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4441: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4447: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4453: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4459: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4465: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4471: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4477: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4483: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4489: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4495: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4501: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4507: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4513: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4519: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4525: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4531: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4537: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4564: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4570: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4576: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4582: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4588: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4594: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4600: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4606: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4612: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4618: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4624: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4630: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4636: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4642: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4648: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4654: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4660: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4666: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4672: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4678: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4684: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4690: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4696: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4702: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4708: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4714: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4720: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4726: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4732: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4738: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4744: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4750: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4756: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4762: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4767: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4772: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4777: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4782: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4792: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4802: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4812: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4823: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4833: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4843: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4853: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4863: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4869: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4875: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4885: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4895: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4905: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4915: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4921: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4927: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4933: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4939: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4950: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4961: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4971: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4981: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4987: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4993: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:4999: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5005: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5015: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5025: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5035: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5045: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5051: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5057: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5063: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5069: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5075: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5085: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5095: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5105: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5115: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5121: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5127: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5133: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5139: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5150: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5161: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5172: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5183: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5189: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5195: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5201: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5207: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5217: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5227: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5237: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5247: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5257: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5267: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5277: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5287: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5297: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5307: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5317: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5327: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5337: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5347: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5357: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5367: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5377: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5387: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5397: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5407: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5417: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5427: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5437: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5447: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5457: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5467: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5477: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5487: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5497: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5507: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5517: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5527: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5537: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5547: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5557: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5567: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5577: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5587: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5597: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5607: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5617: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5627: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5637: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5647: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5658: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5669: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5680: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5691: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5734: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5763: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5799: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5823: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5867: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5918: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5925: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5932: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5939: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:5972: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6005: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6012: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6017: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6022: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6081: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6099: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6144: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6203: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6223: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6280: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6303: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6317: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6331: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6345: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6351: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6357: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6395: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6444: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6467: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6473: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6497: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6508: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6513: ERROR:  current transaction is aborted, commands ignored until end of transaction block
psql:lwpostgis.sql:6518: ERROR:  current transaction is aborted, commands ignored until end of transaction block
ROLLBACK
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081020/56a03bc2/attachment.sig>
