[postgis-devel] 1.3.4rc1
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Oct 21 14:12:46 PDT 2008
On Sun, 2008-10-19 at 20:42 -0700, Paul Ramsey wrote:
> The PostGIS team is pleased to provide release version 1.3.4rc1 for
> your testing delectation.
> You may download it from:
> http://postgis.refractions.net/download
> For extra fun, you can also download the SVN version of GEOS, which
> includes support for "prepared geometry" acceleration of
> ST_Intersects(), ST_Contains() and ST_Covers().
> 1.3.4 includes a number of bug fixes, and support for accelerated
> testing of point-in-polygon cases of intersects, contains, within,
> etc. With the SVN snapshot of GEOS, accelerated support is extended to
> all geometry types.
> The SVN version of GEOS is available from:
> http://download.osgeo.org/geos/geos-svn.tar.bz2
Okay, I've finally found a few moments to test on Win32. Compilation goes
fine, but regression blows up big style on the geojson test for which I've
attached the diff :( It seems to be precision related, but there must be
something different in the code since the problem doesn't occur at all in
the rest of the tests.
Incidentally I managed to successfully build against GEOS-3.0.2 using
Regina's patch, so again it would be good to get this into GEOS 3.0 branch
SVN.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20081021/f06e804e/attachment.obj>
