[postgis-devel] 1.3.4rc1
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Sun Oct 26 14:13:27 PDT 2008
Mark Cave-Ayland wrote:
> Okay, I've finally found a few moments to test on Win32. Compilation goes
> fine, but regression blows up big style on the geojson test for which I've
> attached the diff :(  It seems to be precision related, but there must be
> something different in the code since the problem doesn't occur at all in
> the rest of the tests.
I've spent some time today looking at this and the problem is a symptom
of different floating point precision(s) and the use of the %f format
specifier.
The first thing to note is that the differences in floating point
implementations will always be present, no matter what we try and do.
The trick, of course, is to restrict our regression tests to the lowest
common precision denominator that will pass on all platforms.
Currently the geojson code format identifiers look like this: %.*f where
the * is used to indicate the number of decimal places. Now
unfortunately this is incorrect because the precision of the floating
point answer is related to the size of the mantissa (and hence the
number of significant figures) rather than the number of decimal places.
  So depending upon whether the calculation is done in hardware or
software, the compiler options and even program order, the resulting
output is likely to be different.
The double-precision IEEE floating point format specifies a 64-bit
number with a 53-bit mantissa, which translates into approximately 14
significant figures. So in order to solve this, I'd like to propose
changing the meaning of the precision parameter from decimal places to
significant figures, and changing the geojson output formats to %*f with
a maximum precision of 14.
In my testing here, this gives identical results between gcc and MingW
for 99.9% of cases, with the small 0.1% being caused by MingW adding a
trailing "0" to the output when rounding in some cases. I would suggest
that if there are cases like this in the regression tests after
conversion then we simply alter the input coordinates to prevent this
from happening.
So I'd like to go ahead and do this to 1.3 branch / trunk so that we can
cleanly pass regression tests on at least gcc/msvcrt in order to get
1.3.4 out of the door. Anyone have any major objections?
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
