[postgis-devel] Minimum number of points in a POLYGON ring?
David Fuhry dfuhry at acm.org
Fri Sep 19 17:01:09 PDT 2008
Mark,
> Oracle Spatial
> So wow. While some behaviour can be implied from the documentation, the
> point at which validation occurs is such a grey area that all I can
> suggest is that we actually try some non-closed polygons in different
> databases and see what happens. Any volunteers? ;)
Oracle Spatial itself does no validity checks:
SQL> create table tt as select sdo_geometry(2003, null, null,
sdo_elem_info_array(1,1003,3), sdo_ordinate_array(0,0, 0,1, 1,1, 1,0,
0,0)) as geom from dual;
Table created.
SQL> update tt a set a.geom.sdo_ordinates = sdo_ordinate_array(0,1,2);
1 row updated.
SQL> commit;
Commit complete.
SQL> select geom from tt;
SDO_GEOMETRY(2003, NULL, NULL, SDO_ELEM_INFO_ARRAY(1, 1003, 3),
SDO_ORDINATE_ARRAY(0, 1, 2))
> Then again, it seems a few people are interested in being able to
> brute-force bad things into the database to fix them up later. I think
> that integrating liblwgeom into shp2pgsql/pgsql2shp would allow some
> kind of --force option that would by-pass the parser checks by calling a
> stored procedure such as "SELECT postgis_parser_check(0)" which would
> turn off the checks for the duration of that session. Does that sound
> like a reasonable compromise?
Yes, that approach sounds very reasonable.
Thanks,
Dave
