[postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Eduin Carrillo yecarrillo at gmail.com
Wed Apr 22 00:00:44 PDT 2009
Mark, what KML test fails?
Eduin Yesid Carrillo Vega
Ingeniero Civil, Esp. Sistemas de Información Geográfica
Grupo IDE & GIG
Centro de Investigación y Desarrollo en Información Geográfica
Instituto Geográfico Agustín Codazzi - IGAC
Cr 30 48-51
Tel +57 1 3694000  ext 4305
Bogotá D.C., Colombia
On Wed, Apr 22, 2009 at 1:52 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paragon Corporation wrote:
>> Okay just tried on my OpenSUSE 11 box.  Make check fails on kml check.  It
>> looks like a rounding error.  I assume that is okay.
> Not really. If 1.3.5 passes all tests on the same box then it should be
> considered a regression. It's probably worth giving Olivier a poke, as we
> spent some time at the code sprint adding precision specifiers to the
> regression tests to remove this problem. I can't remember whether the
> changes were done for the 1.3 branch as well as trunk though.
> ATB,
> Mark.
