[postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Paragon Corporation lr at pcorp.us
Wed Apr 22 00:15:02 PDT 2009
Eduin,
The last test on the make check regression list (whatever is number 40 I
guess).  I assume that is the kml.sql test?
Anyrate on 2 its off by the last digit.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Eduin
Carrillo
Sent: Wednesday, April 22, 2009 3:01 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Any chance we can get a 1.3.6 RC1 out this week
Mark, what KML test fails?
Eduin Yesid Carrillo Vega
Ingeniero Civil, Esp. Sistemas de Información Geográfica Grupo IDE & GIG
Centro de Investigación y Desarrollo en Información Geográfica Instituto
Geográfico Agustín Codazzi - IGAC Cr 30 48-51 Tel +57 1 3694000  ext 4305
Bogotá D.C., Colombia
On Wed, Apr 22, 2009 at 1:52 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paragon Corporation wrote:
>> Okay just tried on my OpenSUSE 11 box.  Make check fails on kml
>> check.  It looks like a rounding error.  I assume that is okay.
> Not really. If 1.3.5 passes all tests on the same box then it should
> be considered a regression. It's probably worth giving Olivier a poke,
> as we spent some time at the code sprint adding precision specifiers
> to the regression tests to remove this problem. I can't remember
> whether the changes were done for the 1.3 branch as well as trunk though.
> ATB,
> Mark.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
