[postgis-devel] Typmod Goodness
Paragon Corporation lr at pcorp.us
Fri Aug 7 12:18:09 PDT 2009
Paul and Kevin,
I disagree with the pg_table_is_visible = true addition (if it ensures only
tables in your search path).
The reason being -- isn't this supposed to be like a geometry_columns
Lets say you logically divide your database by departmental schemas (or us
states or function (e.g hydrology, assessing etc.) -- normally you just
query a certain one, but I would often
want to query other departmental/state tables even if they aren't in my
search path and I would fully qualify those.  Shouldn't I be able to see the
geometry/geography meta data of these without switching my search_path?
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, August 07, 2009 2:20 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Typmod Goodness
On Fri, Aug 7, 2009 at 11:13 AM, Kevin Neufeld<kneufeld at refractions.net>
wrote:
> Paul Ramsey wrote:
>>> And, may I ask why you filtered out pg_temp tables?  Why would you
>>> not what to list geography columns on any temporary tables you may
>>> have made?
>> I'll turn the question back to you, since I created the view by
>> copying populate_geometry_columns :)
> :) Ah.  populate_geometry_columns repopulates geometry_columns from
> all geometry columns detected in the database.  The pg_temp filter is
> used here for the main reason that without it, temporary tables from
> *all* users would be retrieved. It's not appropriate (or permissible)
> to access a temp table in another users' session ... so why even list
> them in the first place, right?  Also, another albeit weak answer is
> that since it's a static table (not a view) listing a geometry column
> that will disappear in the very near future may not seem like a good thing
to do.
> With the geography_columns view, you would need the pg_temp filter IF
> you don't have the additional filter of pg_table_is_visible().  But if
> you're only looking at tables in your search_path (which can't
> possible include temp tables of other users), then you would have the
> option to list temp tables that are, in fact, available to you.
> Anywho, it's just a thought for discussion.  I don't know what the
> specs say about it.
The specs are silent. I've incorporated both your suggestions.
P
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
