[postgis-devel] Typmod Goodness
Stephen Frost sfrost at snowman.net
Fri Aug 7 12:36:06 PDT 2009
* Paragon Corporation (lr at pcorp.us) wrote:
> I disagree with the pg_table_is_visible = true addition (if it ensures only
> tables in your search path).
So do I.  I equate 'geometry_columns' and 'geography_columns' to
'pg_class', 'pg_tables', or 'information_schema.tables', none of which
have any such filter based on current search_path.  That's something
implemented in the client, where necessary and appropriate.
	Thanks,
		Stephen
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090807/382444a0/attachment.sig>
