[postgis-devel] Typmod Goodness
Kevin Neufeld kneufeld at refractions.net
Fri Aug 7 12:52:28 PDT 2009
I'm not partial either way, but perhaps it might be an idea to follow Oracle's example:
http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_objrelschema.htm#i1001937
Have two views. One to list the geography_columns in the user's search_path, and one to list all geography_columns which
the user has select access to.
-- Kevin
Stephen Frost wrote:
> * Paragon Corporation (lr at pcorp.us) wrote:
>> I disagree with the pg_table_is_visible = true addition (if it ensures only
>> tables in your search path).
> So do I.  I equate 'geometry_columns' and 'geography_columns' to
> 'pg_class', 'pg_tables', or 'information_schema.tables', none of which
> have any such filter based on current search_path.  That's something
> implemented in the client, where necessary and appropriate.
> 	Thanks,
> 		Stephen
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
