[postgis-devel] Strange result about spatial indexes?
Tom Lane tgl at sss.pgh.pa.us
Fri Aug 14 21:38:24 PDT 2009
Paul Ramsey <pramsey at cleverelephant.ca> writes:
> Frankly, now that we know this trick, since most of our index calls
> are now hidden inside SQL facades (eg ST_Intersects()), we can further
> wrap the index operations in no-op immutable functions to force this
> behavior. And add an ST_MBRIntersects() function which does nothing
> more than toss in a wrapper function. It's a hack, but c'est la vie.
> Most of the time the effect won't be 10:1 like this example data set
> showed -- this data just happens to have some high degrees of overlap,
> so the inefficiency gets lots of exercise.
This is definitely the exact same issue that Mark Cave-Ayland complained
about last year:
http://archives.postgresql.org/pgsql-hackers/2008-06/msg00384.php
The proposal I had to fix it
http://archives.postgresql.org/pgsql-hackers/2008-06/msg00709.php
more or less crashed and burned, because it was too complicated and
didn't buy enough in return.  But I wonder if we couldn't fix your
problem with a less ambitious, less invasive approach, like the
attached.  Which is actually a three-statement patch, but it looks
bigger because I had to rearrange the existing code a trifle.
This is against CVS HEAD, but applies cleanly to 8.4, and could be
applied to 8.3 with only minor work.
			regards, tom lane
Index: src/backend/executor/nodeIndexscan.c
RCS file: /cvsroot/pgsql/src/backend/executor/nodeIndexscan.c,v
retrieving revision 1.133
diff -c -r1.133 nodeIndexscan.c
*** src/backend/executor/nodeIndexscan.c	18 Jul 2009 19:15:41 -0000	1.133
--- src/backend/executor/nodeIndexscan.c	15 Aug 2009 04:28:55 -0000
*** 237,244 ****
--- 237,247 ----
  ExecIndexEvalRuntimeKeys(ExprContext *econtext,
  						 IndexRuntimeKeyInfo *runtimeKeys, int numRuntimeKeys)
+ 	MemoryContext oldContext;
  	int			j;
+ 	oldContext = MemoryContextSwitchTo(econtext->ecxt_per_tuple_memory);
  	for (j = 0; j < numRuntimeKeys; j++)
  		ScanKey		scan_key = runtimeKeys[j].scan_key;
*** 256,273 ****
  		 * econtext->ecxt_per_tuple_memory.  We assume that the outer tuple
  		 * will stay put throughout our scan.  If this is wrong, we could copy
  		 * the result into our context explicitly, but I think that's not
! 		 * necessary...
! 		scanvalue = ExecEvalExprSwitchContext(key_expr,
! 											  econtext,
! 											  &isNull,
! 											  NULL);
! 		scan_key->sk_argument = scanvalue;
  		if (isNull)
  			scan_key->sk_flags |= SK_ISNULL;
  		else
  			scan_key->sk_flags &= ~SK_ISNULL;
--- 259,290 ----
! 		 * necessary.
! 		 * It's also entirely possible that the result of the eval is a
! 		 * toasted value.  In this case we should forcibly detoast it,
! 		 * to avoid repeat detoastings each time the value is examined
! 		 * by an index support function.
! 		scanvalue = ExecEvalExpr(key_expr,
! 								 econtext,
! 								 &isNull,
! 								 NULL);
  		if (isNull)
+ 			scan_key->sk_argument = scanvalue;
  		else
+ 			if (runtimeKeys[j].key_toastable)
+ 				scanvalue = PointerGetDatum(PG_DETOAST_DATUM(scanvalue));
+ 	MemoryContextSwitchTo(oldContext);
*** 795,800 ****
--- 812,819 ----
  				runtime_keys[n_runtime_keys].scan_key = this_scan_key;
  				runtime_keys[n_runtime_keys].key_expr =
  					ExecInitExpr(rightop, planstate);
+ 				runtime_keys[n_runtime_keys].key_toastable =
+ 					TypeIsToastable(op_righttype);
  				n_runtime_keys++;
  				scanvalue = (Datum) 0;
*** 844,849 ****
--- 863,893 ----
  				varattno = ((Var *) leftop)->varattno;
+ 				 * We have to look up the operator's associated btree support
+ 				 * function
+ 				opno = lfirst_oid(opnos_cell);
+ 				opnos_cell = lnext(opnos_cell);
+ 				if (index->rd_rel->relam != BTREE_AM_OID ||
+ 					varattno < 1 || varattno > index->rd_index->indnatts)
+ 					elog(ERROR, "bogus RowCompare index qualification");
+ 				opfamily = index->rd_opfamily[varattno - 1];
+ 				get_op_opfamily_properties(opno, opfamily,
+ 										   &op_strategy,
+ 										   &op_lefttype,
+ 										   &op_righttype);
+ 				if (op_strategy != rc->rctype)
+ 					elog(ERROR, "RowCompare index qualification contains wrong operator");
+ 				opfuncid = get_opfamily_proc(opfamily,
+ 											 op_lefttype,
+ 											 op_righttype,
+ 											 BTORDER_PROC);
  				 * rightop is the constant or variable comparison value
  				rightop = (Expr *) lfirst(rargs_cell);
*** 867,902 ****
  					runtime_keys[n_runtime_keys].scan_key = this_sub_key;
  					n_runtime_keys++;
- 				 * We have to look up the operator's associated btree support
- 				 * function
- 				opno = lfirst_oid(opnos_cell);
- 				opnos_cell = lnext(opnos_cell);
- 				if (index->rd_rel->relam != BTREE_AM_OID ||
- 					varattno < 1 || varattno > index->rd_index->indnatts)
- 					elog(ERROR, "bogus RowCompare index qualification");
- 				opfamily = index->rd_opfamily[varattno - 1];
- 				get_op_opfamily_properties(opno, opfamily,
- 										   &op_strategy,
- 										   &op_lefttype,
- 										   &op_righttype);
- 				if (op_strategy != rc->rctype)
- 					elog(ERROR, "RowCompare index qualification contains wrong operator");
- 				opfuncid = get_opfamily_proc(opfamily,
- 											 op_lefttype,
- 											 op_righttype,
- 											 BTORDER_PROC);
  				 * initialize the subsidiary scan key's fields appropriately
  				ScanKeyEntryInitialize(this_sub_key,
--- 911,923 ----
  					n_runtime_keys++;
Index: src/include/nodes/execnodes.h
RCS file: /cvsroot/pgsql/src/include/nodes/execnodes.h,v
retrieving revision 1.206
diff -c -r1.206 execnodes.h
*** src/include/nodes/execnodes.h	6 Aug 2009 20:44:31 -0000	1.206
--- src/include/nodes/execnodes.h	15 Aug 2009 04:28:55 -0000
*** 1084,1089 ****
--- 1084,1090 ----
  	ScanKey		scan_key;		/* scankey to put value into */
  	ExprState  *key_expr;		/* expr to evaluate to get value */
+ 	bool		key_toastable;	/* is expr's result a toastable datatype? */
  } IndexRuntimeKeyInfo;
  typedef struct
