[postgis-devel] [PostGIS] #243: proj4 statically compiled into postgis-1.4.dll
PostGIS trac at osgeo.org
Mon Aug 24 00:22:09 PDT 2009
  Reporter:  jpalmer      |       Owner:  robe
      Type:  enhancement  |      Status:  assigned
  Priority:  medium       |   Milestone:  postgis 1.4.1
 Component:  postgis      |     Version:  1.4.X
Resolution:               |    Keywords:  win32, build, dll, library, proj
Comment (by mcayland):
 Ah. The missing part of the voodoo incantation is this:
 gcc -shared -o libproj.dll -Wl,--out-implib=libproj.dll.a -Wl,--export-
 all-symbols -Wl,--enable-auto-import -Wl,--whole-archive libproj.a -Wl,
 --no-whole-archive /c/mingw/lib/libmingw32.a
 Otherwise you end up linking against the .a static version produced by
 default under Win32. Note that you can check whether this has worked by
 running the resulting postgis-1.4.dll through MS's depends.exe.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/243#comment:2>
