[postgis-devel] [PostGIS] #243: proj4 statically compiled into postgis-1.4.dll
PostGIS trac at osgeo.org
Mon Aug 24 12:58:54 PDT 2009
  Reporter:  jpalmer      |       Owner:  robe
      Type:  enhancement  |      Status:  closed
  Priority:  medium       |   Milestone:  postgis 1.4.1
 Component:  postgis      |     Version:  1.4.X
Resolution:  fixed        |    Keywords:  win32, build, dll, library, proj
Changes (by robe):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Thanks.  Update the instructions.
 Jpalmer -- by the way if you need this sooner than 1.4.1 comes out let me
 know.  We have a build of trunk (1.5) and branch 1.4 and just testing it
 out before we upload to the experimental section.  Should ahve this
 tomorrow.  I've corrected this in our build script so moving forward it
 should be right.
 Anyrate th 1.4.1 SVN has just minor fixes to current 1.4 (mostly remove of
 debug messages and the ST_AsGML crash issue with empty geometrie
 collection as I recall)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/243#comment:3>
