[postgis-devel] problem with spatial_ref_sys.sql
Zico mailzico at gmail.com
Thu Aug 27 10:22:34 PDT 2009
I have been trying to configure "fixmystreet" in my Debian 5.0 machine. I am
following the doc:
https://www.socialtext.net/lukec/index.cgi?howto_set_up_fixmystreet_ca_developer_environment
But, here, when i go for the command:
 *sudo -u postgres psql -d fixmystreet -f
/usr/share/postgresql-8.3-postgis/spatial_ref_sys.sql
Then the error comes:
*psql:/usr/share/postgresql-8.3-postgis/spatial_ref_sys.sql:12757: ERROR:
current transaction is aborted, commands ignored until end of transaction
block
ROLLBACK
psql:/usr/share/postgresql-8.3-postgis/spatial_ref_sys.sql:12759: ERROR:
relation "spatial_ref_sys" does not exist
How can i get rid off this problem? I need to setup this server as early as
possible. So need your help badly.
Best,
Zico
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090827/e0fdec79/attachment.html>
