[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
PostGIS trac at osgeo.org
Mon Dec 21 08:48:30 PST 2009
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by mcayland):
 Well I prefer the directory hack version for its simplicity, but I have
 also engineered the alternative which is putting the version number in the
 .sql  and _comments.sql files. Please try the attached proof of concept
 patch.
 One thing to note using this method is that it will be necessary to patch
 the documentation to insert version numbers into any references to
 postgis.sql/uninstall_postgis.sql.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:6>
