[postgis-devel] [PostGIS] #311: Rename postgis.sql topostgis-1.5.sql
Paul Ramsey pramsey at cleverelephant.ca
Thu Dec 24 09:05:03 PST 2009
So what's your vote? Honestly, I need every PSC member to express a
preference, so we don't just stare at this issue for 2 weeks and
*then* get around to voting. It's stupid, it's trivial, but I can't
cowboy it, and it needs to be resolved before release.
I'll vote for #3 then.
P.
On Wed, Dec 23, 2009 at 10:42 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul,
> Mark can correct me, but I do believe the
> " Mark has a rage-induced aneurism and dies tragically."
> Goes with plan 2 :)
> or I at least will have a rage induced aneurism with plan 2.
> There are already thousands of files in share/contrib so I don't even run my
> sql files from that folder when I am installing PostGIS on Linux (I use the
> source folder).
> In other cases it really doesn't matter since other contribs usually have
> just one sql file and one uninstall (maybe).
> Now FWIW, I can grudgingly live with the versioned file names.  Just can't
> live with everything in the same folder.
> Especially when we are talking about (n) postgis.sql,  (n*4)
> postgis_upgrade..., (n) postgis_uninstall
> Thanks,
> Regina
> Well, that leaves us with several options, all of which gores someone's ox:
> 1. Leave the install exactly the way it is now, and Regina continues
> to make a "special" one for Windows. Unix and Windows don't match,
> directory-wise, but they do match filename-wise. Unix has less version
> info in the .sql files than Windows.
> 2. Change the install to have a versioned postgis-1.5.sql file
> installed directly into share/contrib along with all the other .sql
> files. Unix and Windows don't match directory-wise or file-wise, but
> Unix users get a versioned .sql file to match their .so files.
> 3. Hack the Makefile to override the pgxs install and installdirs
> targets to replicate Regina's Windows scheme. Unix and Windows match
> both directory-wise and file-wise, and Unix gets some version
> information to go with their .sql files. Mark has a rage-induced
> Anyone care to start choosing so we can have a release?
> P.
> On Wed, Dec 23, 2009 at 5:50 PM, PostGIS <trac at osgeo.org> wrote:
>> Comment (by robe):
>>  contrib/postgis (this is folder shared by all that contains proj)
>>  contrib/postgis-1.4
>>  contrib/postgis-1.5
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
