[postgis-devel] Issue 111 in postgis: Enhancement request - Minimum Bounding Circle for PostGIS
codesite-noreply at google.com codesite-noreply at google.com
Mon Feb 2 12:44:17 PST 2009
Status: New
Owner: ----
New issue 111 by rind... at lrcwe.com: Enhancement request - Minimum Bounding
Circle for PostGIS
http://code.google.com/p/postgis/issues/detail?id=111
Here is a proposed new function for Minimum Bounding Circle in PostGIS 1.4.
  This can be added to lwpostgis_upgrade.sql  and lwpostgis.sql since it is
all a stored procedure.
The results of the function is a polygon buffer representing the minimum
bounding circle.  The default buffer has 192 verticies but this can be
increased.  The Roeck test can be easily computed from this function.  See
http://postgis.refractions.net/pipermail/postgis-users/2008-October/021713.html
The procedure can be improved by adding a Maximum diameter function in GEOS
(not easy ?) and changing my construction of a 3 point circle to a direct
solution.
	MBC.txt  4.3 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
