[postgis-devel] Issue 109 in postgis: Some operators not supported for Circular
codesite-noreply at google.com codesite-noreply at google.com
Tue Feb 3 10:10:39 PST 2009
Comment #3 on issue 109 by mark.cav... at siriusit.co.uk: Some operators not
http://code.google.com/p/postgis/issues/detail?id=109
'Fix' committed as r3636. Does that look better?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
