[postgis-devel] Issue 91 in postgis: "makefile check" Shows check failed of sql-mm-circularstring in PostGIS
codesite-noreply at google.com codesite-noreply at google.com
Sun Jan 4 05:33:58 PST 2009
Status: New
Owner: ----
New issue 91 by vibhor.aim: "makefile check" Shows check failed of
http://code.google.com/p/postgis/issues/detail?id=91
What steps will reproduce the problem?
1. Download the product source
2. execute ./configure then make and make install
3. then execute make check
What is the expected output? What do you see instead?
Expected Output should succeeded. Following error came:
  sql-mm-circularstring. failed (diff expected
obtained: /tmp/pgis_reg_9121/test_28_diff)
  sql-mm-compoundcurve. failed (diff expected
obtained: /tmp/pgis_reg_9121/test_29_diff)
  sql-mm-curvepoly. failed (diff expected
obtained: /tmp/pgis_reg_9121/test_30_diff)
  sql-mm-multicurve. failed (diff expected
obtained: /tmp/pgis_reg_9121/test_32_diff)
  sql-mm-multisurface. failed (diff expected
obtained: /tmp/pgis_reg_9121/test_33_diff)
What version of the product are you using? On what operating system?
OS: Red Hat Enterprise Linux Server release 5 (Tikanga), 32 bit
PostGIS: 1.3.5
Postgresql: 8.3.5
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
