[postgis-devel] GUI Time
Paul Ramsey pramsey at opengeo.org
Mon Jan 5 07:34:30 PST 2009
shp2pgsql.c will remain, untouched. Once the new stuff is ready to
test, I'll just commit it along-side. We can remove the old version
once we're certain we like the new ones.
I'm planning on using the shp2pgsq-core.o object in both the
executables, so that's kind of like a library :)
P.
On Jan 5, 2009, at 2:18 AM, Mark Cave-Ayland wrote:
> Paul Ramsey wrote:
>> Hi folks,
>> My Christmas present to myself was trying to do a GUI for shape
>> importing (and eventually exporting). It turned out the GUI wasn't
>> too hard... unfortunately when it came time to bolt in the actual
>> guts, the crufty legacy code got in the way... the assumption of
>> emitting to stdout is pretty backed in. So getting this working is
>> going to take a pretty radical re-work. I'll work off to the side
>> of the existing code, and create three new bits:
>> shp2pgsql-core.c  - where the work gets done
>> shp2pgsql-gui.c  - the gui frontend
>> shp2pgsql-cli.c  - the commandline frontend
>> Best,
>> P.
> Yup indeed. I did some testing on liblwgeom over Christmas (see
> email to follow over the next few days) and realised that the
> existing dual memory model is just plain bad.
> My feeling is that we need to get liblwgeom to the point where we
> can rip out the lwgeom_init_allocators() callback and handle the
> memory management/errors ourselves, so this would be one less thing
> for you to worry about.
> But yeah, the loaders aren't the best example of C coding around and
> so I wouldn't be averse to them being reworked. Perhaps similar to
> liblwgeom you could make shp2pgsql-core.c a static library which
> gets linked into both the CLI and GUI versions? I'd suggest if this
> is major work then it should go into a separate branch so that trunk
> will work as is, and then import the code into trunk when you have
> something tested that works.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Paul Ramsey
OpenGeo - http://opengeo.org
PostGIS is Love.
