[postgis-devel] Issue 89 in postgis: transform() grid-shift 2nd chance logic defective
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 9 08:25:43 PST 2009
Comment #6 on issue 89 by william.... at acm.org: transform() grid-shift 2nd
http://code.google.com/p/postgis/issues/detail?id=89
Mark, my previous comment omitted (a) the real root cause of this problem
and (b)
two possible fixes that might leave us both reasonably satisfied.
Real root cause, highlighted by your last remark:  proj.4's error return
code
currently makes no distinction between (1) unavailable grid shift files and
(2)
points that fall outside the boundaries of an available grid shift file.
Best possible fix: PostGIS would throw an error in case 1 and throw a
warning in
case 2 -- but there's presently no way for PostGIS to distinguish between
the two
cases.  Any chance you could get the proj.4 team to add a distinct error
code and
message for case 2?
Second-choice fix: return NULL when proj.4 reports a grid-shift error (in
either
error case above).  The user who wishes to obtain a non-grid-shifted
transform as a
fallback could then do so with coalesce().  On the other hand, a user who
unexpectedly has rows with geometries that fall outside the area for which
the grid
shift is defined could easily identify all such rows in a single SELECT,
which is
impossible if you throw an error on the first offense.  Finally, users who
are
missing a necessary grid-shift file at least won't get SLIGHTLY different
answers
from systems that have the necessary files; this should make it easier for
them to
find their real problem.
Throwing a generic error like PostGIS now does makes it very difficult for
a user
whose table contains a subset of rows with geometries outside a grid-shift
region to
identify those offending rows.  The user must discover the boundaries of
the grid
shift file (how?), then craft a query to find geometries that fall outside
tha area.
One last thought about improving the warning in my preferred fix:  my
current patch
throws a warning for every offending POINT; this increases error-handling
load by
several orders of magnitude for complex geometries.  Better would be to
throw one
warning for every GEOMETRY with an offending point, identifying the
offendor by the
first line of the geometry's summary() plus the coordinates of the first
point in
the geometry and the first offending point (if different).  I haven't dug
into the
PostGIS transform code enough to see how difficult this might be.
Sorry to belabor this, but the current generic error behavior really cost
me a lot
of time, and I'd like to save others the inconvenience.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
