[postgis-devel] Issue 89 in postgis: transform() grid-shift 2nd chance logic defective
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 9 03:55:32 PST 2009
Comment #5 on issue 89 by william.... at acm.org: transform() grid-shift 2nd
http://code.google.com/p/postgis/issues/detail?id=89
Correction: 2nd bullet above, second sentence, first word, "PosgGIS" should
read
"proj.4".  Sorry.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
