[postgis-devel] Issue 94 in postgis: Rename folders/files to be more consistent
codesite-noreply at google.com codesite-noreply at google.com
Mon Jan 12 03:40:43 PST 2009
Comment #3 on issue 94 by mark.cav... at siriusit.co.uk: Rename folders/files
http://code.google.com/p/postgis/issues/detail?id=94
Regina: this also brings in the issue that since PROJ.4 is compulsary for
SVN trunk,
should we automatically #include spatial_ref_sys into postgis.sql?
Paul: I don't have a problem with renaming files on a minor version bump.
Anything
that changes a minor release screams "there have been some changes here,
please test
first before deployment". So as long as we document this, I don't see this
being a
problem.
Also, I'd still like to propose version numbering the so/DLL - this will
make
testing/installing multiple versions so much easier. I don't see upgrades
being a
problem, since you don't need to know the name of so/DLL containing a
function to be
able to drop it, and the upgrade script for version X already knows the
name of its
own so/DLL. I'm sure we can also devise something that will flag big
warnings/errors
if mixed so/DLL versions are present in the system catalogs.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
