[postgis-devel] WKTRaster: RASTER and CHIP
strk strk at keybit.net
Tue Jan 27 07:41:50 PST 2009
On Fri, Jan 16, 2009 at 05:31:58PM +0000, Mark Cave-Ayland wrote:
> I think Paul summarised in his email what I was saying but in much fewer
> words; working in a branch is kinda okay as long as the WKTRaster
> developers don't mind constant merging from trunk/fixing things based on
> changes to the PostGIS core. Although my feeling is for the initial cut,
> it may be less work to host the project independently and do a first
> merge when it reaches a relatively stable point.
I think we found a good compromise by using the 'spike'
subdir of posgis SVN root, as per Paul suggestion and thanks
to Kevin.
It is an isolated spot so won't pollute distribution
or svn checkouts (unless pulled from the root).
 http://svn.refractions.net/postgis/spike/wktraster/
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
