[postgis-devel] Multi-D Indexing and Serialized Form
Paul Ramsey pramsey at cleverelephant.ca
Mon Jul 13 14:28:33 PDT 2009
Yes, if we are willing to re-calculate the full bounding box for
comparison purposes, every time we need it. For large geometries, this
is a bad trade-off. But that speaks again to simply calculating the
fully dimensional bbox. We don't currently have a very clever use of
the clever "optional bbox" trick dave baked into the initial revision,
but that clever trick gets us a long way if we don't use bboxes at all
for smaller geometries that we are fine with calculating the bbox for
every time.
On Mon, Jul 13, 2009 at 2:26 PM, Chris Hodgson<chodgson at refractions.net> wrote:
> Doesn't the indexing code have control over what type of bbox it creates
> from the geometry when it is building the index? ie. the 2-d indexing code
> can create 2-d boxes and the 3-d indexing code can create 3-d boxes,
> regardless of the geometry's original number of dimensions.
> Chris
> Paul Ramsey wrote:
>> For my "geography" work, I am trying to ensure that what I do either
>> uses existing liblwgeom hooks, or creates new things that liblwgeom2
>> could use. I'll be doing indexing as a 3-space index, and that works
>> OK for geography, things are static:
>> bbox dims = 3
>> coordinate dims = 2
>> However, for geometry, we were thinking about adding multidimensional
>> indexing. Right now we have a situation like this for geometry:
>> bbox dims = 2
>> coordinate dims = 2/3/4
>> No problem, because we only calculate a 2d box, no matter what our
>> dimensionality. But when we add the possibility of multi-dimensional
>> indexes, we get in a bind. How many dimensions of bbox should we
>> calculate? We need enough to support the index, but we don't know what
>> the dimensionality of the index using the bbox will be. That leaves us
>> forced to calculate the full multi-dimensional bbox even if we only
>> want a 2-d index. We also could end up with some interesting problems,
>> for example, returning results from a 4d index given a 2d query bbox.
>> The straightest line solution, IMO, is to just create a bbox with
>> enough dimensionality to handle the coordinates. So we'll end up with
>> coordinate dims = 2 => bbox dims = 2
>> coordinate dims = 3 => bbox dims = 3
>> coordinate dims = 4 => bbox dims = 4
>> For 2-vertex 3d points that you only want a 2d index on (the worst
>> case, since we don't put boxes on points), that implies a storage
>> overhead of about 10%.
>> P.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
