[postgis-devel] Multi-D Indexing and Serialized Form
Chris Hodgson chodgson at refractions.net
Mon Jul 13 14:44:53 PDT 2009
Oh, I understand, you're not talking about what dimension of bbox gets
stored in the index, you're talking about how many dimensions the bbox
in the geometry object is... in which case, I think you're straight-line
solution seems to make the most sense. Otherwise it is an additional
parameter that you have to specify when you create your geometry column
- how many dimensions is the bbox.
Chris
Paul Ramsey wrote:
> Yes, if we are willing to re-calculate the full bounding box for
> comparison purposes, every time we need it. For large geometries, this
> is a bad trade-off. But that speaks again to simply calculating the
> fully dimensional bbox. We don't currently have a very clever use of
> the clever "optional bbox" trick dave baked into the initial revision,
> but that clever trick gets us a long way if we don't use bboxes at all
> for smaller geometries that we are fine with calculating the bbox for
> every time.
> O
