[postgis-devel] st_intersect crasher
David Fuhry dfuhry at acm.org
Thu Jul 16 21:05:22 PDT 2009
Mark Cave-Ayland wrote:
> Is this from an SVN checkout or a release tarball? If it's from the
> tarball, can you try from a checkout instead?
Updating geos to SVN HEAD and postgis to 1.4.0rc2 fixed the problem.  I
never did get it fully diagnosed.
Before updating, I rebuilt the old postgis with --enable-debug, and the
st_intersection call output (attached) looked as expected - a geos
crash, but with nothing unusual-looking before that.
Strangely, the attached geos_test.c succeeded.  I thought that ldd
showed both its binary and the postgres shared object in PKGLIBDIR /
$libdir (/usr/lib/postgresql/8.3/lib) linked to the same libgeos and
libgeos_c objects, although I could have been wrong about that.
-Dave
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090717/60849c58/attachment.txt>
Type: text/x-csrc
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090717/60849c58/attachment.c>
