[postgis-devel] problem with makefile in MinGW in trunk
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Jul 17 04:16:13 PDT 2009
nicklas.aven at jordogskog.no wrote:
> it returned:
> PATH=.:/usr/local/bin:/mingw/bin:/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/System32/Wbem:/c/Programfiler/Hewlett-Packard/IAM/bin:/c/Programfiler/Windows
> Imaging/:/c/WINDOWS/system32/WindowsPowerShell/v1.0:/mingw/bin:/c/Programfiler/Microsoft
> SQL Server/100/Tools/Binn/:/c/Programfiler/Microsoft SQL
> Server/100/DTS/Binn/:/c/Programfiler/Microsoft SQL
> Server/100/Tools/Binn/VSShell/Common7/IDE/:/c/Programfiler/TortoiseSVN/bin:/c/strawberry/c/bin:/c/strawberry/perl/bin
> PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.PSC1
> PYTHONPATH=C:\Programfiler\ArcGIS\bin
> PKG_CONFIG_PATH=/mingw/lib/pkgconfig
That looks okay. Please try the attached regress/Makefile and see what
TESTPATH looks like. It should be the same as above, except with the
path to your PostgreSQL bin directory prepended.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090717/4ab5b202/attachment.ksh>
