[postgis-devel] Vote for 1.4 Release
Paul Ramsey pramsey at cleverelephant.ca
Wed Jul 22 14:11:36 PDT 2009
I think you have clock issues. Everything fails from regress because
regress calls this:
make -C ../postgis
Which means regress thinks that postgis is out of date (even though
you just built it) which indicates you've got some sync issues.
P.
On Wed, Jul 22, 2009 at 2:00 PM, Kevin Neufeld<kneufeld at refractions.net> wrote:
> K, well, since everyone else can get it working then I must be doing
> something wierd cuz I can't get the regression to actually run.  I can get
> PostGIS installed and working just fine ... I just can't get the regression
> suite to run.
> I don't see any issues when using a similar script against the 1.3 branch.
> Attached is a script and results I get when trying to run regression against
> an empty 8.2.13 install. (error occurs in line 326 in log file) pg_config is
> not found.
> If you're convinced it's just me, then I vote +1 as well.
> -- Kevin
> Kevin Neufeld wrote:
>> I'm just running regression now.  At first glance, I don't get the same
>> errors as with trunk when running postgis.sql, but I am getting the same
>> make regress errors.
>> Looking a little more into this now.
>> -- Kevin
>> Paragon Corporation wrote:
>>> Good.  So we are just waiting for Kevin since Mark has already giving his
>>> blessing.
>>> -----Original Message-----
>>> From: postgis-devel-bounces at postgis.refractions.net
>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>>> Ramsey
>>> Sent: Wednesday, July 22, 2009 3:09 PM
>>> To: PostGIS Development Discussion
>>> Subject: Re: [postgis-devel] Vote for 1.4 Release
>>> Nope, I vote +1, I'd rather have a release out than not. And the volume
>>> of
>>> bug reports will help us determine what stupid regression mistakes we
>>> have
>>> left in place and whether they are important.
>>> P.
>>> On Wed, Jul 22, 2009 at 12:01 PM, Paragon Corporation<lr at pcorp.us> wrote:
>>>> Paul,
>>>> No.  We had pushed that to 1.4.1
>>>> http://trac.osgeo.org/postgis/ticket/222
>>>> This is beginning to sound like a
>>>> "But, we have waited for so long why don't we put the icing on the cake
>>>> and wait for the GUI to compile under windows?"
>>>> If you are thinking that then we should probably have an RC3 and take
>>>> care of the upgrade issue I mentioned here
>>>> http://trac.osgeo.org/postgis/ticket/223
>>>> I'm pretty sure our upgrade script is missing the box3d_extents
>>>> autocasts.
>>>> I also feel we should make the box3d_extent --> box2d CAST explicit
>>>> instead of implicit.
>>>> I believe that is the CAST that is causing me problems when I restore a
>>>> 1.3 db unto  a fresh 1.4 db and I question its value since I think most of
>>>> our functions Have casts for box3d.  That I haven't tested though.
>>>>  Thanks,
>>>> Regina
>>>> Ramsey
>>>> Sent: Wednesday, July 22, 2009 1:01 PM
>>>> Does the GUI build?
>>>> On Wed, Jul 22, 2009 at 9:26 AM, Paragon Corporation<lr at pcorp.us> wrote:
>>>>>  We have successfully make checked under windows for 8.2,8.3,8.4
>>>>>  Can we have a 1.4 release
>>>>>  +1
>>>>> Thanks,
>>>>> Regina
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> #!/bin/sh -x
> export WORKSPACE=`pwd`
> # Add PostgreSQL libraries to path
> POSTGRESQL_HOME=${HOME}/opt/pgsql/8.2
> export LD_LIBRARY_PATH=${POSTGRESQL_HOME}/lib
> export PATH=/usr/local/bin:/bin:/usr/bin:${POSTGRESQL_HOME}/bin
> export PGPORT=8213
> # Add GEOS support
> GEOS_HOME=${HOME}/opt/geos/3.1.0
> export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:${GEOS_HOME}/lib
> # Add Proj support
> PROJ_HOME=${HOME}/opt/proj/4.6.1
> export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:${PROJ_HOME}/lib
> # Checkout source code
> svn -q co http://svn.osgeo.org/postgis/branches/1.4 src
> # Build project
> cd src
> ./autogen.sh
> ./configure \
>   --prefix=${WORKSPACE}/build/ \
>   --with-pgconfig=${POSTGRESQL_HOME}/bin/pg_config \
>   --with-geosconfig=${GEOS_HOME}/bin/geos-config \
>   --with-projdir=${PROJ_HOME}
> make
> make install
> export LD_LIBRARY_PATH=${LD_LIBRARY_PATH}:${WORKSPACE}/build/lib
> # Regression Test
> cd regress
> make
> # Cleanup
> cd ${WORKSPACE}/src
> make uninstall
> ++ pwd
> + export WORKSPACE=/var/home/buildbot/workspace
> + WORKSPACE=/var/home/buildbot/workspace
> + POSTGRESQL_HOME=/var/home/buildbot/opt/pgsql/8.2
> + export LD_LIBRARY_PATH=/var/home/buildbot/opt/pgsql/8.2/lib
> + LD_LIBRARY_PATH=/var/home/buildbot/opt/pgsql/8.2/lib
> + export
> PATH=/usr/local/bin:/bin:/usr/bin:/var/home/buildbot/opt/pgsql/8.2/bin
> + PATH=/usr/local/bin:/bin:/usr/bin:/var/home/buildbot/opt/pgsql/8.2/bin
> + export PGPORT=8213
> + PGPORT=8213
> + GEOS_HOME=/var/home/buildbot/opt/geos/3.1.0
> + export
> LD_LIBRARY_PATH=/var/home/buildbot/opt/pgsql/8.2/lib:/var/home/buildbot/opt/geos/3.1.0/lib
> + PROJ_HOME=/var/home/buildbot/opt/proj/4.6.1
> + export
> LD_LIBRARY_PATH=/var/home/buildbot/opt/pgsql/8.2/lib:/var/home/buildbot/opt/geos/3.1.0/lib:/var/home/buildbot/opt/proj/4.6.1/lib
> + svn -q co http://svn.osgeo.org/postgis/branches/1.4 src
> + cd src
> + ./autogen.sh
> * Running /usr/bin/libtoolize (1.5.22)
> \tOPTIONS = --force --copy
> You should add the contents of `/usr/share/aclocal/libtool.m4' to
> `aclocal.m4'.
> * Running /usr/bin/aclocal (1.9.6)
> * Running /usr/bin/autoconf (2.59)
> Now you are ready to run './configure'
> + ./configure --prefix=/var/home/buildbot/workspace/build/
> --with-pgconfig=/var/home/buildbot/opt/pgsql/8.2/bin/pg_config
> --with-geosconfig=/var/home/buildbot/opt/geos/3.1.0/bin/geos-config
> --with-projdir=/var/home/buildbot/opt/proj/4.6.1
> checking build system type... i686-redhat-linux-gnu
> checking host system type... i686-redhat-linux-gnu
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for a sed that does not truncate output... /bin/sed
> checking for egrep... grep -E
> checking for ld used by gcc... /usr/bin/ld
> checking if the linker (/usr/bin/ld) is GNU ld... yes
> checking for /usr/bin/ld option to reload object files... -r
> checking for BSD-compatible nm... /usr/bin/nm -B
> checking whether ln -s works... yes
> checking how to recognise dependent libraries... pass_all
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking dlfcn.h usability... yes
> checking dlfcn.h presence... yes
> checking for dlfcn.h... yes
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking how to run the C++ preprocessor... g++ -E
> checking for g77... no
> checking for f77... no
> checking for xlf... no
> checking for frt... no
> checking for pgf77... no
> checking for fort77... no
> checking for fl32... no
> checking for af77... no
> checking for f90... no
> checking for xlf90... no
> checking for pgf90... no
> checking for epcf90... no
> checking for f95... no
> checking for fort... no
> checking for xlf95... no
> checking for ifc... no
> checking for efc... no
> checking for pgf95... no
> checking for lf95... no
> checking for gfortran... no
> checking whether we are using the GNU Fortran 77 compiler... no
> checking whether  accepts -g... no
> checking the maximum length of command line arguments... 32768
> checking command to parse /usr/bin/nm -B output from gcc object... ok
> checking for objdir... .libs
> checking for ar... ar
> checking for ranlib... ranlib
> checking for strip... strip
> checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -fPIC
> checking if gcc PIC flag -fPIC works... yes
> checking if gcc static flag -static works... yes
> checking if gcc supports -c -o file.o... yes
> checking whether the gcc linker (/usr/bin/ld) supports shared libraries...
> yes
> checking whether -lc should be explicitly linked in... no
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... yes
> configure: creating libtool
> appending configuration tag "CXX" to libtool
> checking for ld used by g++... /usr/bin/ld
> checking whether the g++ linker (/usr/bin/ld) supports shared libraries...
> yes
> checking for g++ option to produce PIC... -fPIC
> checking if g++ PIC flag -fPIC works... yes
> checking if g++ static flag -static works... yes
> checking if g++ supports -c -o file.o... yes
> yes
> appending configuration tag "F77" to libtool
> checking for gcc... (cached) gcc
> checking whether we are using the GNU C compiler... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for gcc option to accept ANSI C... (cached) none needed
> checking whether we are using the GNU C++ compiler... (cached) yes
> checking whether g++ accepts -g... (cached) yes
> checking if g++ supports -Wall... yes
> checking if g++ supports -Wmissing-prototypes... yes
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking lex output file root... lex.yy
> checking whether yytext is a pointer... yes
> checking for bison... bison -y
> checking ieeefp.h usability... no
> checking ieeefp.h presence... no
> checking for ieeefp.h... no
> checking for convert... /usr/bin/convert
> checking for xsltproc... /usr/bin/xsltproc
> checking for dblatex... /usr/bin/dblatex
> checking CUnit/CUnit.h usability... yes
> checking CUnit/CUnit.h presence... yes
> checking for CUnit/CUnit.h... yes
> checking for CU_initialize_registry in -lcunit... yes
> checking iconv.h usability... yes
> checking iconv.h presence... yes
> checking for iconv.h... yes
> checking for libiconv_open in -liconv... no
> checking for iconv_open in -lc... yes
> Using user-specified pg_config file:
> checking libpq-fe.h usability... yes
> checking libpq-fe.h presence... yes
> checking for libpq-fe.h... yes
> checking for PQserverVersion in -lpq... yes
> Using user-specified geos-config file:
> checking geos_c.h usability... yes
> checking geos_c.h presence... yes
> checking for geos_c.h... yes
> checking for initGEOS in -lgeos_c... yes
> Using user-specified proj directory: /var/home/buildbot/opt/proj/4.6.1
> checking proj_api.h usability... yes
> checking proj_api.h presence... yes
> checking for proj_api.h... yes
> checking for pj_get_release in -lproj... yes
> configure: creating ./config.status
> config.status: creating liblwgeom/Makefile
> config.status: creating liblwgeom/cunit/Makefile
> config.status: creating postgis/Makefile
> config.status: creating postgis/sqldefines.h
> config.status: creating loader/Makefile
> config.status: creating topology/Makefile
> config.status: creating regress/Makefile
> config.status: creating doc/Makefile
> config.status: creating doc/html/image_src/Makefile
> config.status: creating postgis_config.h
>  PostGIS is now configured for i686-redhat-linux-gnu
>  -------------- Compiler Info -------------
>  C compiler:           gcc -g -O2
>  C++ compiler:         g++ -g -O2
>  -------------- Dependencies --------------
>  GEOS config:          /var/home/buildbot/opt/geos/3.1.0/bin/geos-config
>  GEOS version:         3.1
>  PostgreSQL config:    /var/home/buildbot/opt/pgsql/8.2/bin/pg_config
>  PostgreSQL version:   8.2
>  PROJ4 version:        46
>  PostGIS debug level:  0
>  -------- Documentation Generation --------
>  xsltproc:             /usr/bin/xsltproc
>  xsl style sheets:     /usr/share/sgml/docbook/xsl-stylesheets
>  dblatex:              /usr/bin/dblatex
>  convert:              /usr/bin/convert
> + make
> make -C liblwgeom
> make[1]: Entering directory `/var/home/buildbot/workspace/src/liblwgeom'
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o measures.o
> measures.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o box2d.o box2d.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o ptarray.o
> ptarray.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwgeom_api.o
> lwgeom_api.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwgeom.o lwgeom.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwpoint.o
> lwpoint.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwline.o lwline.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwpoly.o lwpoly.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmpoint.o
> lwmpoint.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmline.o
> lwmline.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmpoly.o
> lwmpoly.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwcollection.o
> lwcollection.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwcircstring.o
> lwcircstring.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwcompound.o
> lwcompound.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwcurvepoly.o
> lwcurvepoly.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmcurve.o
> lwmcurve.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwmsurface.o
> lwmsurface.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwutil.o lwutil.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwalgorithm.o
> lwalgorithm.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwgunparse.o
> lwgunparse.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwgparse.o
> lwgparse.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lwsegmentize.o
> lwsegmentize.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o wktparse.tab.o
> wktparse.tab.c
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o lex.yy.o lex.yy.c
> lex.yy.c:4127: warning: ‘yyunput’ defined but not used
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes  -c -o vsprintf.o
> vsprintf.c
> ar rs liblwgeom.a measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o
> lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o
> lwcircstring.o lwcompound.o lwcurvepoly.o lwmcurve.o lwmsurface.o lwutil.o
> lwalgorithm.o lwgunparse.o lwgparse.o lwsegmentize.o wktparse.tab.o lex.yy.o
> vsprintf.o
> ar: creating liblwgeom.a
> make[1]: Leaving directory `/var/home/buildbot/workspace/src/liblwgeom'
> make -C postgis
> make[1]: Entering directory `/var/home/buildbot/workspace/src/postgis'
> gcc -E -traditional-cpp postgis.sql.in.c | grep -v '^#' > postgis.sql.in
> sed 's,MODULE_PATHNAME,$libdir/postgis-1.4,g' postgis.sql.in >postgis.sql
> gcc -E -traditional-cpp uninstall_postgis.sql.in.c | grep -v '^#' >
> sed 's,MODULE_PATHNAME,$libdir/uninstall_postgis-1.4,g'
> uninstall_postgis.sql.in >uninstall_postgis.sql
> "/usr/bin/perl" ../utils/postgis_proc_upgrade.pl postgis.sql >
> postgis_upgrade.sql
> gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Winline
> -Wdeclaration-after-statement -Wendif-labels -fno-strict-aliasing -fwrapv
> -fpic -I/var/home/buildbot/opt/geos/3.1.0/include
> -I/var/home/buildbot/opt/proj/4.6.1/include -I../liblwgeom -I.
> -I/var/home/buildbot/opt/pgsql/8.2/include/server
> -I/var/home/buildbot/opt/pgsql/8.2/include/internal -D_GNU_SOURCE   -c -o
> lwgeom_pg.o lwgeom_pg.c
> lwgeom_debug.o lwgeom_debug.c
> lwgeom_accum.o lwgeom_accum.c
> lwgeom_spheroid.o lwgeom_spheroid.c
> lwgeom_ogc.o lwgeom_ogc.c
> lwgeom_functions_analytic.o lwgeom_functions_analytic.c
> lwgeom_inout.o lwgeom_inout.c
> lwgeom_estimate.o lwgeom_estimate.c
> lwgeom_functions_basic.o lwgeom_functions_basic.c
> lwgeom_gist.o lwgeom_gist.c
> lwgeom_btree.o lwgeom_btree.c
> lwgeom_transform.o lwgeom_transform.c
> lwgeom_transform.c:144: warning: initialization from incompatible pointer
> type
> lwgeom_box.o lwgeom_box.c
> lwgeom_box3d.o lwgeom_box3d.c
> lwgeom_box2dfloat4.o lwgeom_box2dfloat4.c
> lwgeom_chip.o lwgeom_chip.c
> lwgeom_chip.c: In function ‘CHIP_in’:
> lwgeom_chip.c:175: warning: format ‘%ld’ expects type ‘long int’, but
> argument 4 has type ‘unsigned int’
> lwgeom_geos.o lwgeom_geos.c
> lwgeom_geos_prepared.o lwgeom_geos_prepared.c
> lwgeom_geos_prepared.c:106: warning: initialization from incompatible
> pointer type
> lwgeom_svg.o lwgeom_svg.c
> lwgeom_gml.o lwgeom_gml.c
> lwgeom_kml.o lwgeom_kml.c
> lwgeom_geojson.o lwgeom_geojson.c
> lwgeom_triggers.o lwgeom_triggers.c
> lwgeom_dump.o lwgeom_dump.c
> lwgeom_functions_lrs.o lwgeom_functions_lrs.c
> long_xact.o long_xact.c
> lwgeom_sqlmm.o lwgeom_sqlmm.c
> lwgeom_rtree.o lwgeom_rtree.c
> ar crs libpostgis-1.4.a lwgeom_pg.o lwgeom_debug.o lwgeom_accum.o
> lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o
> lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o
> lwgeom_transform.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o
> lwgeom_chip.o lwgeom_geos.o lwgeom_geos_prepared.o lwgeom_svg.o lwgeom_gml.o
> lwgeom_kml.o lwgeom_geojson.o lwgeom_triggers.o lwgeom_dump.o
> lwgeom_functions_lrs.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o
> ranlib libpostgis-1.4.a
> -fpic -shared -Wl,-soname,libpostgis-1.4.so.0   lwgeom_pg.o lwgeom_debug.o
> lwgeom_accum.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
> lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o
> lwgeom_btree.o lwgeom_transform.o lwgeom_box.o lwgeom_box3d.o
> lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_geos.o lwgeom_geos_prepared.o
> lwgeom_svg.o lwgeom_gml.o lwgeom_kml.o lwgeom_geojson.o lwgeom_triggers.o
> lwgeom_dump.o lwgeom_functions_lrs.o long_xact.o lwgeom_sqlmm.o
> lwgeom_rtree.o -L/var/home/buildbot/opt/geos/3.1.0/lib
> -L/var/home/buildbot/opt/proj/4.6.1/lib
> -L/var/home/buildbot/opt/pgsql/8.2/lib -lgeos_c -lproj
> ../liblwgeom/liblwgeom.a -Wl,-rpath,'/var/home/buildbot/opt/pgsql/8.2/lib'
> -o libpostgis-1.4.so.0.0
> rm -f libpostgis-1.4.so.0
> ln -s libpostgis-1.4.so.0.0 libpostgis-1.4.so.0
> make[1]: Leaving directory `/var/home/buildbot/workspace/src/postgis'
> make -C loader
> make[1]: Entering directory `/var/home/buildbot/workspace/src/loader'
> -I. -I/var/home/buildbot/opt/pgsql/8.2/include/server
> shpopen.o shpopen.c
> dbfopen.o dbfopen.c
> getopt.o getopt.c
> shp2pgsql.o shp2pgsql.c
> shpopen.o dbfopen.o getopt.o shp2pgsql.o ../liblwgeom/liblwgeom.a -lc -lm -o
> shp2pgsql
> -I/var/home/buildbot/opt/pgsql/8.2/include -c pgsql2shp.c
> shpopen.o dbfopen.o getopt.o pgsql2shp.o ../liblwgeom/liblwgeom.a -lc
> -L/var/home/buildbot/opt/pgsql/8.2/lib -lpq -lm -o pgsql2shp
> make[1]: Leaving directory `/var/home/buildbot/workspace/src/loader'
> make -C utils
> make[1]: Entering directory `/var/home/buildbot/workspace/src/utils'
> chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl
> profile_intersects.pl test_estimation.pl test_joinestimation.pl
> make[1]: Leaving directory `/var/home/buildbot/workspace/src/utils'
> PostGIS was built successfully. Ready to install.
> + make install
> make -C liblwgeom
> make[1]: Nothing to be done for `all'.
> make -C postgis
> make -C loader
> make -C utils
> make -C postgis install
> /bin/sh
> /var/home/buildbot/opt/pgsql/8.2/lib/pgxs/src/makefiles/../../config/install-sh
> -c -m 644 ./../spatial_ref_sys.sql
> '/var/home/buildbot/opt/pgsql/8.2/share/contrib'
> /bin/sh
> -c -m 644 postgis.sql '/var/home/buildbot/opt/pgsql/8.2/share/contrib'
> /bin/sh
> -c -m 644 uninstall_postgis.sql
> /bin/sh
> -c -m 644 postgis_upgrade.sql
> /bin/sh
> -c -m 755  libpostgis-1.4.so.0.0
> '/var/home/buildbot/opt/pgsql/8.2/lib/postgis-1.4.so'
> make -C loader install
> /bin/sh
> -c pgsql2shp /var/home/buildbot/opt/pgsql/8.2/bin
> /bin/sh
> -c shp2pgsql /var/home/buildbot/opt/pgsql/8.2/bin
> + export
> LD_LIBRARY_PATH=/var/home/buildbot/opt/pgsql/8.2/lib:/var/home/buildbot/opt/geos/3.1.0/lib:/var/home/buildbot/opt/proj/4.6.1/lib:/var/home/buildbot/workspace/build/lib
> + cd regress
> + make
> make -C ../postgis
> make[1]: pg_config: Command not found
> cp ../postgis/postgis.sql .
> ./run_test: line 388: psql: command not found
> Creating spatial db postgis_reg
> ./run_test: line 395: createdb: command not found
> ./run_test: line 396: createlang: command not found
> ./run_test: line 415: psql: command not found
>  Something went wrong (no postgis installed in postgis_reg).
>  For details, check /tmp/pgis_reg_27118/regress_log
> make: *** [test] Error 1
> + cd /var/home/buildbot/workspace/src
> + make uninstall
> make -C postgis uninstall
> rm -f '/var/home/buildbot/opt/pgsql/8.2/share'/contrib/spatial_ref_sys.sql
> '/var/home/buildbot/opt/pgsql/8.2/share'/contrib/postgis.sql
> '/var/home/buildbot/opt/pgsql/8.2/share'/contrib/uninstall_postgis.sql
> '/var/home/buildbot/opt/pgsql/8.2/share'/contrib/postgis_upgrade.sql
> rm -f '/var/home/buildbot/opt/pgsql/8.2/lib/postgis-1.4.so'
> make -C loader uninstall
> make -C doc uninstall
> make[1]: Entering directory `/var/home/buildbot/workspace/src/doc'
> rm -f /var/home/buildbot/opt/pgsql/8.2/doc/postgis/postgis.html
> rm -f /var/home/buildbot/opt/pgsql/8.2/doc/postgis/README.postgis
> rm -f /var/home/buildbot/opt/pgsql/8.2/man/man1/shp2pgsql.1
> rm -f /var/home/buildbot/opt/pgsql/8.2/man/man1/pgsql2shp.1
> make[1]: Leaving directory `/var/home/buildbot/workspace/src/doc'
> make -C doc comments-uninstall
> rm -f /var/home/buildbot/opt/pgsql/8.2/share/contrib/postgis_comments.sql
