[postgis-devel] configure error while building WKTRaster onUbuntu8.10
Tyler Erickson tyler.erickson at mtu.edu
Tue Mar 3 08:55:01 PST 2009
With Sandro's modification to autogen.sh, the configure step now works
without an error.
Note that I am getting a similar configure error while building the
postgis trunk, maybe it needs the same modification?
- Tyler
taericks at latituded830b:postgis-trunk$ ./configure
--prefix=/usr/local/postgis/trunk --datadir=$PG_SHARE
--with-geosconfig=/usr/local/geos/3.0.0/bin/geos-config
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared
libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether we are using the GNU C++ compiler... (cached) yes
checking whether g++ accepts -g... (cached) yes
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared
libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
libraries... yes
checking if g++ supports -Wall... yes
checking if g++ supports -Wmissing-prototypes... (cached) yes
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking for xsltproc... /usr/bin/xsltproc
checking for db2pdf... /usr/bin/db2pdf
checking for dblatex... /usr/bin/dblatex
configure: WARNING: could not locate Docbook stylesheets required to
build the documentation
checking CUnit/CUnit.h usability... no
checking CUnit/CUnit.h presence... no
checking for CUnit/CUnit.h... no
configure: WARNING: could not locate CUnit required for liblwgeom unit tests
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... yes
checking for pg_config... /usr/bin/pg_config
checking libpq-fe.h usability... yes
checking libpq-fe.h presence... yes
checking for libpq-fe.h... yes
checking for PQserverVersion in -lpq... yes
Using user-specified geos-config file: /usr/local/geos/3.0.0/bin/geos-config
checking geos_c.h usability... yes
checking geos_c.h presence... yes
checking for geos_c.h... yes
checking for initGEOS in -lgeos_c... yes
checking proj_api.h usability... yes
checking proj_api.h presence... yes
checking for proj_api.h... yes
checking for pj_get_release in -lproj... yes
configure: creating ./config.status
config.status: creating liblwgeom/Makefile
config.status: creating liblwgeom/cunit/Makefile
config.status: creating postgis/Makefile
config.status: creating postgis/sqldefines.h
config.status: creating loader/Makefile
config.status: creating topology/Makefile
config.status: creating regress/Makefile
config.status: creating doc/Makefile
config.status: creating postgis_config.h
config.status: executing libtool commands
sed: can't read ./ltmain.sh: No such file or directory
mv: cannot stat `libtoolT': No such file or directory
cp: cannot stat `libtoolT': No such file or directory
chmod: cannot access `libtool': No such file or directory
taericks at latituded830b:postgis-trunk$ svn update
At revision 3788.
Mateusz Loskot wrote:
> strk wrote:
>> On Tue, Mar 03, 2009 at 04:02:53PM -0000, Mateusz Loskot wrote:
>>>> (1) Why would my build look for ltmain.sh (since strk indicated
>> that
>>>> the build script doesn't use libtool) ?
>>> Sandro, so what is the libtool stuff checked for, in configure.ac?
>> Overlooked that, it seems libtool is used to figure PIC flags.
>> I committed a modified autogen.sh adding the final libtoolize call.
>> Works for me. ltmain.sh here (Ubuntu 8.10 too) is created by
>> the libtoolize call as a symlink.
> Sandro, thanks. The fix works for me.
> Mateusz Loskot
> Senior Programmer, Cadcorp
> http://www.cadcorp.com
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Tyler A. Erickson, Ph.D.
Research Scientist, Michigan Tech Research Institute, and
Adjunct Assistant Professor, Dept. of Civil & Environmental Engineering
Michigan Technological University
3600 Green Court, Suite 100
Ann Arbor, MI 48105
W 83.6889°, N 42.3021° (WGS84)
(734) 913-6846
http://people.mtri.org/tyler+erickson
http://www.mtri.org
http://www.michiganview.org
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090303/b36bb5bc/attachment.html>
