[postgis-devel] Issue 119 in postgis: ST_AsSVG crashedDBbackendwith large geometries.
Courtin Olivier olivier.courtin at gmail.com
Tue Mar 10 03:42:18 PDT 2009
On Mar 10, 2009, at 12:30 AM, Obe, Regina wrote:
Regina,
> I retested on my same box (blowing out my whole svn and
> redownloading from scratch and still run into the same issues.).
> I'll be able to test on windows aond my other OpenSUSe tomorrow.
Ok let me know...
> Anyrate I am running
> "POSTGIS="1.4.0SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec
> 2007" USE_STATS"  (also verifeid it was built minutes ago)
> "PostgreSQL 8.3.1 on i686-pc-linux-gnu, compiled by GCC gcc (SUSE
> Linux) 4.3.1 20080507 (prerelease) [gcc-4_3-branch revision 135036]"
> I wonder if its my gcc or something that is the culprit.  Below is
> list of things that works and what crashes. Seems to crash when it
> gets to polygons. If others could test on their platforms that would
> be super.
Do you have the same one with following compilation procedure ?
CFLAGS="-g -O0" ./configure
make clean
make
sudo make install
> --polygon crashes server
>         SELECT ST_AsSVG(foo1.the_geom)
>                         FROM ((SELECT
> ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)  As the_geom
>                 FROM generate_series(-10,50,10) As i
>                         CROSS JOIN generate_series(40,70, 20) As j))
> As foo1;
Could you create a postgis database foo and then run as a postgres user:
echo "SELECT ST_AsSVG(foo1.the_geom) FROM ((SELECT
ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)  As the_geom FROM
generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20)
As j)) As foo1;" | valgrind --leak-check=yes -v --run-libc-freeres=no
--show-reachable=yes --log-file=valgrindlog /usr/local/pgsql/bin/
postgres --single -D /var/pgsql/data foo
and so valgrindlog file could be interresting...
Olivier
