[postgis-devel] Issue 123 in postgis: SQLite output format support for shp2pgsql
codesite-noreply at google.com codesite-noreply at google.com
Thu Mar 12 05:45:58 PDT 2009
Comment #2 on issue 123 by mark.cav... at siriusit.co.uk: SQLite output format
http://code.google.com/p/postgis/issues/detail?id=123
Hi Schuyler,
I'm not sure about the SQLite changes, however it shows the valid point
that we
shouldn't be using E'....' escaping in shp2pgsql. We should change
shp2pgsql so that
it uses proper SQL escaping (we'd lose pre-8.1 compatibility in the
process, but that
is no longer an issue in trunk) which should help a little.
I'll go ahead and make the changes in trunk.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
