[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 21 17:53:40 PDT 2009
Comment #1 on issue 142 by pwramsey3: 1.4 snapshot build is broken
http://code.google.com/p/postgis/issues/detail?id=142
Could be a symptom of the versions of autotools on the server generating
the snapshots. When I pull down clean
source and run autogen.sh and ./configure I don't even *get* the
line "config.status: executing libtool
commands". I don't have an ltmain.sh file either, which is fine, because in
the version of configure generated by
my autotools (aclocal = 1.10, autoconf = 2.61) ltmain.sh is never called.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
