[postgis-devel] Update Refractions website - 1.3.6
Kevin Neufeld kneufeld at refractions.net
Wed May 6 13:18:04 PDT 2009
You bet.  I'm on it.
Paragon Corporation wrote:
> Kevin or Paul,
> Can you update the PostGIS refractions website news section.  I hope I got
> all the changes.
> PostGIS 1.3.6 (2009-05-06)
>   - Enhancement - PostgreSQL 8.4 compile support (Talha Rizwan, Mark
> Cave-Ayland)
>   - Fix Big fixes for CURVE handling in many functions
>     (Mark Cave-Ayland, Mark Leslie)
>   - Enhancement Trac#34 - pgsql2shp now creates .prj files where applicable
> (Regina Obe)
>   - Fix Trac#88 -  Windows Vista pgsql2shp memory bug (Regina Obe)
>   - Fix Trac#146 - for distance calculation on collections (Nicklas Aven,
> Paul Ramsey)
>   - Fix Trac#116 - crashers for rare EWKB cases (Paul Ramsey)
>   - Fix to address an SRID of -1 in probe_geometry_columns (Kevin Neufeld)
>   - Fix Trac#99 shp2pgsql logical error when importing DBF-only (Regina Obe)
>   - Fix Trac#105 pgsql2shp dbase file creation (EOF marker issue) (Paul
> Ramsey)
>   - Fix updated AddGeometryColumn to throw an error if then specified schema
> does not exist,
>   	rather than throwing a notice and then an error. (Kevin Neufeld)
>   - Fix - Documentation corrections for better handling with PDF DbLatex
> (Kevin Neufeld)
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
