[postgis-devel] 1.3.6 build failures
Kevin Neufeld kneufeld at refractions.net
Thu May 7 15:08:05 PDT 2009
If I read your log correctly, it looks like the JDBC ant script failed since it could locate the postgresql jar  (A few
lines up indicate that your "rpm -ql postgresql-jdbc" line failed to retrieve the package).
-- Kevin
Devrim GÜNDÜZ wrote:
> Hi,
> I just got these on Fedora build servers:
> This is Fedora 10:
> http://koji.fedoraproject.org/koji/getfile?taskID=1341515&name=build.log
> Some related pre-logs:
> http://koji.fedoraproject.org/koji/getfile?taskID=1341515&name=root.log
> http://koji.fedoraproject.org/koji/getfile?taskID=1341515&name=state.log
> This is Fedora-9:
> http://koji.fedoraproject.org/koji/getfile?taskID=1341374&name=build.log
> ..and related pre-logs:
> http://koji.fedoraproject.org/koji/getfile?taskID=1341374&name=root.log
> http://koji.fedoraproject.org/koji/getfile?taskID=1341374&name=state.log
> What could the reason be? Package was built successfully on Fedora 11
> and 12.
> Regards,
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
