[postgis-devel] Documentation layout change possible?
Paragon Corporation lr at pcorp.us
Tue Nov 3 02:24:46 PST 2009
This is more of a question for Kevin,
Is it possible to change our document template so we can have a description
tag in each function proto tag.  Some of our protos are extensive now so its
hard to stuff all these in a single description field without causing a lot
of confusion.  The addition of geography isn't helping the situation.
The main benefit I see aside from putting description next to the relevant
function proto
Is that our psql help will then have a bit more relevant text for the
Now it has
arg1,arg2,arg3 :  function short descrip
(where the arg1,arg2,arg3 currently comes from the function proto
New model would be
arg1, arg2,arg3: function short descrip. function proto description
