[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
PostGIS trac at osgeo.org
Wed Nov 4 08:47:35 PST 2009
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by robe):
 I did a test putting in notices and (had to put in error too because the
 crash prevented me from seeing the notices). Anyrate as far as I can tell
 -- it starts failing in parse_gml_data function  r4734  -- line 846
 Which looks like
 if (!strcmp((char *) xa->name, "pos")) {
 So I guess its either the strcmp or whatever the xa->name is returning.
 For what its worth none of the other code I saw in our codebase does a
 strcmp((char *) ... in one step.
 They always seem to declare the variable char * and use the variable,
 though that may be a stylistic feature rather than for some fundamental
 reason.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:4>
