[postgis-devel] [PostGIS] #230: Put in costs in _ST and possibly other functions
trac at osgeo.org
Sat Nov 7 02:46:43 PST 2009
Reporter: nicklas | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: 1.4
Resolution: fixed | Keywords: st_dwithin st_expand bbox
Comment (by mcayland):
+1 from me, we definitely need to ensure the original test cases work as
defined as its a common use case.
I also notice in your commit you've bumped the minimum PostgreSQL version
to 8.3 in the documentation, although isn't this actually a requirement of
incorporating the new geography typmod code as well as adding costs to
functions? I think any change that requires a minimum PostgreSQL version
change should incur a polite email to -devel for feedback rather than just
committing blind.
Also, if we do bump the minimum version, you need to update the minimum
version check in configure.ac.
ATB,
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/230#comment:27>
