[postgis-devel] [PostGIS] #313: Remove reference.xml and autogenerate from new separate xml docos
trac at osgeo.org
Wed Nov 18 05:48:15 PST 2009
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by colivier):
* owner: pramsey => colivier
Comment:
Yeap the reference,xnml split was not that simple as i initially thought !
It's imply to modify the doc/xsl/* files and the doc/Makefile.in to not
use a single reference.xml one as before.
I plan to fix that before the end of the week.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/313#comment:1>
