[postgis-devel] [PostGIS] #313: Remove reference.xml and autogenerate from new separate xml docos
trac at osgeo.org
Thu Nov 19 06:43:14 PST 2009
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
I was thinking we store the entity definitions in a separate file and we
use Kevin's (or I assume Kevin wrote that ) -- sed trick to macro replace
some <identifiers go here>
with these new items -- that way we can reuse it twice and only define the
identifiers once.
So have cat stitched standalone reference_parser.xml that has the
identifies stitched in.
Then redo it without the identifiers stitched in -- and include this
version in the docs as we have always done.
--- Olivier's NOTE ---
Regina,
> I am totally confused. All the xmls seem invalid since they use
> strange
> new xml terms not defined so can't stand on their own. Is that what
> you
> are talking about Olivier? Where are things like &Z_support; defined?
That's the entity stuff
To avoid to have lot of redundant text, we use entities instead.
But you're right as i have to revert my postgis.xml commit,
entities are no more defined for the moment !
> I was actually thinking we don't use an xml parser to glue
> reference_postgis.xml together
Yeap that's also could be an idea.
But we have also to retrieve the entity stuff from postgis.xml
file, so no sure that will be the best/easy way to do
Olivier
Ticket URL: <http://trac.osgeo.org/postgis/ticket/313#comment:6>
