[postgis-devel] [PostGIS] #315: Entity postgis_aggs_mm not defined
PostGIS trac at osgeo.org
Fri Nov 20 04:25:24 PST 2009
 Reporter:  mloskot  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Complete rebuild of trunk r4866 gives the following error:
 PostGIS was built successfully. Ready to install.
 /usr/bin/make -C doc comments
 make[1]: Entering directory `/home/mloskot/dev/postgis/_svn/trunk/doc'
 /usr/bin/xsltproc ./xsl/postgis_comments.sql.xsl postgis.xml >
 warning: failed to load external entity "postgis_aggs_mm.xml"
 postgis.xml:107: parser error : Failure to process entity postgis_aggs_mm
 postgis.xml:107: parser error : Entity 'postgis_aggs_mm' not defined
 unable to parse postgis.xml
 make[1]: *** [postgis_comments.sql] Error 6
 make[1]: Leaving directory `/home/mloskot/dev/postgis/_svn/trunk/doc'
 make: *** [comments] Error 2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/315>
