[postgis-devel] [PostGIS] #314: Geographic point-in-polygon issue: stab line grazes vertex
trac at osgeo.org
Fri Nov 20 10:37:52 PST 2009
Reporter: pramsey | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by pramsey):
* status: new => closed
* resolution: => fixed
* milestone: PostGIS 2.0.0 => PostGIS 1.5.0
Comment:
Used Nicklas' suggestion to skip past end points on the stab line to fix
both co-linear and grazing cases. Added a number more tests to confirm
this approach and handled first-point-on-line case also. Code looks much
nicer now, thanks Nicklas. r4872
Ticket URL: <http://trac.osgeo.org/postgis/ticket/314#comment:2>
