[postgis-devel] [PostGIS] #260: Geography inconsistent distance behavior from geometry can't compare different dimensonality
trac at osgeo.org
Wed Oct 7 05:03:16 PDT 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version:
Keywords: |
Example with new geography - both the ST_Dwithin and ST_Distance fail
ERROR: gbox_overlaps: geometries have mismatched dimensionality
Again not really a bug I guess just different from geometry behavior
SELECT ST_DWithin(geography(foo1.the_geom),
geography(foo2.the_geom), 100), ST_AsText(foo1.the_geom) As ref1_geom,
ST_AsText(foo2.the_geom) As ref2_geom,
ST_Distance(geography(foo1.the_geom), (foo2.the_geom))
FROM ((
SELECT
ST_GeomFromEWKT('SRID=4326;MULTIPOLYGONM(((0 0 2,10 0 1,10 10 -2,0 10 -5,0
0 -5),(5 5 6,7 5 6,7 7 6,5 7 10,5 5 -2)))') As the_geom
)) As foo1 CROSS JOIN ((SELECT
ST_SetSRID(ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_MakePoint(i+m,j,m),ST_MakePoint(j+m,i-m,m)),ST_MakePoint(i,j,m)),ST_MakePointM(i+m,j,m))),4326)
As the_geom
FROM generate_series(-10,50,20) As i
CROSS JOIN generate_series(50,70, 20) As j
CROSS JOIN generate_series(1,2) As m
ORDER BY i, j, i+j+m, m, i*j*m)) As foo2
LIMIT 2;
Example with plain geometry works
SELECT ST_DWithin(foo1.the_geom, foo2.the_geom, 100),
ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As
ref2_geom, ST_Distance(foo1.the_geom, foo2.the_geom)
FROM ((
SELECT
As the_geom
LIMIT 2;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/260>
