[postgis-devel] [PostGIS] #260: Geography inconsistent distance behavior from geometry can't compare different dimensonality
trac at osgeo.org
Wed Oct 7 05:13:20 PDT 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version:
Resolution: | Keywords:
Comment (by robe):
Though this I would consider a bug (at least an error in the error
message). Gives error
ERROR: gbox_overlaps: geometries have mismatched dimensionality
even though they are the same dimension. If we are not going to allow
these functions to be used with higher dimensions we should change this
error message.
SELECT ST_DWithin(geography(foo1.the_geom),
geography(foo2.the_geom), 100), ST_AsEWKT(foo1.the_geom) As ref1_geom,
ST_AsEWKT(foo2.the_geom) As ref2_geom
FROM ((
SELECT
ST_GeomFromEWKT('SRID=4326;MULTIPOLYGONM(((0 0 2,10 0 1,10 10 -2,0 10 -5,0
0 -5),(5 5 6,7 5 6,7 7 6,5 7 10,5 5 -2)))') As the_geom
)) As foo1 CROSS JOIN ((
SELECT
)) As foo2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/260#comment:1>
