[postgis-devel] [postgis-users] Split line at a given point
Kevin Neufeld
kneufeld at refractions.net
Tue Oct 20 08:17:58 PDT 2009
This seems to be a common use case. Would it make sense to capture
sequences like this to a function for introduction into PostGIS? For
starters, this could be a simple plpgsql function (converted to C at a
later date if the need arises) that accepts a linestring and a point and
returns a multilinestring split at the given point. We already have the
capability of merging linestrings ....
Cheers,
Kevin
Paragon Corporation wrote:
> Shane,
> Use
> http://www.postgis.org/documentation/manual-svn/ST_Line_Locate_Point.html to
> locate the % position it is on the line,
> Then use ST_Line_substring
> http://www.postgis.org/documentation/manual-svn/ST_Line_Substring.html
> So for example
> If you get 0.25 back from ST_Line_Locate_Point
> The trick is the answer you get won't be exactly on the line so you then
> need to do a ST_SetPoint on the other part
> Then the answer you seek would be
> So basically
> Pt is the point
> Line1 = ST_Line_SubString(the_geom, 0, ST_Line_Locate_Point(the_geom) )
> Line2 = ST_Line_SubString(the_geom, ST_Line_Locate_Point(the_geom), 1)
> http://www.postgis.org/documentation/manual-svn/ST_SetPoint.html
> --This part is to get around floating point errors to force the two lines to
> connect back at the juncture
> Line2 = ST_SetPoint(Line2,0 , ST_EndPoint(Line1))
> Leo
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Shane
> Butler
> Sent: Monday, October 19, 2009 6:51 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] Split line at a given point
> Hi all,
> I am trying to split a linestring into two linestrings at a given
> (intersecting) point. Can anyone give me a hint? I have tried
> ST_Difference(mylinestr,mypoint) but it just returns mylinestr...
> Im using: "POSTGIS="1.3.5" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.6.1,
> 21 August 2008" USE_STATS"
> Kind Regards,
> Shane
> postgis-users mailing list
