[postgis-devel] ST_GeomFromGML
Olivier Courtin olivier.courtin at oslandia.com
Thu Oct 22 01:59:50 PDT 2009
On Oct 21, 2009, at 9:38 PM, Paragon Corporation wrote:
Regina,
> What is the minimum version of libxml2 required for this?  We should
> probably document the version in the installation documentation.
I've done some quick version tests based on the current code,
it's begin to work with libxml2 2.4.0 (released on july 2001)
I have to check this again at the end as i plan to use some other
features from libxml2 (namespaces, xlink)
> By the way my magical GCC is a Susie not a Fedora :)  I need to
> reset it up
> on my new workstation so haven't had a chance to test it out under
> OpenSUSE.
Ok !
Olivier
