[postgis-devel] [PostGIS] #279: hausdorff regression test fails
trac at osgeo.org
Fri Oct 30 05:48:14 PDT 2009
Reporter: mloskot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords: hausdorff
Old description:
> Running regression tests against PostGIS from current trunk (r4706) gives
> failure for the ''hausdorff'' test
> hausdorff. failed (diff expected obtained:
> /tmp/pgis_reg_25454/test_44_diff)
> and it looks it crashes the server
> $ cat /tmp/pgis_reg_25454/test_44_diff
> *** hausdorff_expected 2009-07-30 10:28:11.000000000 +0100
> --- /tmp/pgis_reg_25454/test_44_out 2009-10-30 12:38:58.000000000
> +0000
> *** 3,6 ****
> hausdorff_ls_ls_2|2
> hausdorff_ls_mp|1
> hausdorff_ls_ls_3|14.142135623731
> ! hausdorffdensify_ls_ls|70
> --- 3,9 ----
> hausdorff_ls_ls_2|2
> hausdorff_ls_mp|1
> ! server closed the connection unexpectedly
> ! This probably means the server terminated abnormally
> ! before or while processing the request.
> ! connection to server was lost
> Environment:
> * Linux 64-bit
> * GCC 4.4.1
> * GEOS (version 3.2.0 from SVN trunk
> [http://trac.osgeo.org/geos/changeset/2710 2710])
New description:
+0000
*** 3,6 ****
hausdorff_ls_ls_2|2
hausdorff_ls_mp|1
--- 3,9 ----
hausdorff_ls_ls_2|2
hausdorff_ls_mp|1
I did full rebuild of both, PostGIS and GEOS.
Environment:
* Linux 64-bit
* GCC 4.4.1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/279#comment:1>
