[postgis-devel] [PostGIS] #478: [wktraster] There seems to be an offset in ST_Envelope or ST_Box2D
PostGIS trac at osgeo.org
Thu Apr 8 11:56:54 PDT 2010
  Reporter:  robe       |       Owner:  pracine
      Type:  defect     |      Status:  new
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by robe):
 I think the problem here might be that the PixelYSize is being set wrong.
 It should be negative instead of positive.
 Remember I had posted an invalid bug #489 about why I'm getting negative
 pixel y sizes, and Mike Toews corrected me and said they usually are
 negative.
 Well for the gif and png samples I loaded, I noticed the PixelYSize was
 coming in as 1 so I changed it to -1 and that made everything line up
 right.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/478#comment:14>
