[postgis-devel] [PostGIS] #506: PostGIS 1.5.1 causing postmaster 8.3 crash on index creation
PostGIS trac at osgeo.org
Fri Apr 23 18:06:05 PDT 2010
 Reporter:  nick     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.2
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 Just upgraded to PostGIS 1.5.1 on a windows XP machine (from 1.3.4) with
 Postgres 8.3 and when creating an index on a geography column using this
 single statement;
 CREATE INDEX t_swath_metadata_swath_bounding_key ON t_swath_metadata
 USING gist (swath_bounding);
 I get a client error
 DEBUG:  StartTransactionCommandDEBUG:  StartTransactionDEBUG:  name:
 unnamed; blockState:       DEFAULT; state: INPROGR, xid/subid/cid: 0/1/0,
 nestlvl: 1, children:DEBUG:  ProcessUtilityDEBUG:  mapped win32 error code
 2
 to 2
 ********** Error **********
 and find the entire server / postmaster has crashed and no longer running.
 Log below;
 2010-04-15 22:35:12 EST LOG:  database system was interrupted; last known
 up
 at 2010-04-15 22:32:33 EST
 2010-04-15 22:35:12 EST LOG:  database system was not properly shut down;
 automatic recovery in progress
 2010-04-15 22:35:13 EST LOG:  redo starts at C/F5D9EAB0
 2010-04-15 22:35:13 EST LOG:  loaded library
 "$libdir/plugins/plugin_debugger.dll"
 2010-04-15 22:35:13 EST FATAL:  the database system is starting up
 2010-04-15 22:35:13 EST LOG:  unexpected pageaddr C/EEFDE000 in log file
 12,
 segment 246, offset 16637952
 2010-04-15 22:35:13 EST LOG:  redo done at C/F6FDCC90
 2010-04-15 22:35:13 EST LOG:  last completed transaction was at log time
 2010-04-15 22:33:37.687+10
 2010-04-15 22:35:14 EST LOG:  loaded library
 2010-04-15 22:35:14 EST FATAL:  the database system is starting up
 2010-04-15 22:35:14 EST LOG:  database system is ready to accept
 connections
 2010-04-15 22:35:15 EST LOG:  loaded library
 2010-04-15 22:36:22 EST LOG:  loaded library
 2010-04-15 22:36:26 EST LOG:  loaded library
 2010-04-15 22:36:27 EST LOG:  loaded library
 2010-04-15 22:36:35 EST LOG:  server process (PID 14600) was terminated by
 exception 0xC0000005
 2010-04-15 22:36:35 EST HINT:  See C include file "ntstatus.h" for a
 description of the hexadecimal value.
 2010-04-15 22:36:35 EST LOG:  terminating any other active server
 processes
 2010-04-15 22:36:35 EST WARNING:  terminating connection because of crash
 of
 another server process
 2010-04-15 22:36:35 EST DETAIL:  The postmaster has commanded this server
 process to roll back the current transaction and exit, because another
 server process exited abnormally and possibly corrupted shared memory.
 2010-04-15 22:36:35 EST HINT:  In a moment you should be able to reconnect
 to the database and repeat your command.
 of
 2010-04-15 22:36:35 EST LOG:  all server processes terminated;
 reinitializing
 2010-04-15 22:36:36 EST FATAL:  pre-existing shared memory block is still
 in
 use
 2010-04-15 22:36:36 EST HINT:  Check if there are any old server processes
 still running, and terminate them.
 I have been using this Postgresql instance (8.3) with PostGIS 1.3.4 for a
 long time previously to do similar operations on geometries and never
 encountered a crash like this.
 I must admit there is not much to go on with that log above - raising to
 debug shows below:
 2010-04-15 22:48:57 EST DEBUG:  StartTransactionCommand
 2010-04-15 22:48:57 EST DEBUG:  name: unnamed; blockState:       DEFAULT;
 state: INPROGR, xid/subid/cid: 0/1/0, nestlvl: 1, children:
 2010-04-15 22:48:57 EST DEBUG:  ProcessUtility
 2010-04-15 22:48:57 EST DEBUG:  mapped win32 error code 2 to 2
 2010-04-15 22:48:59 EST DEBUG:  reaping dead processes
 2010-04-15 22:48:59 EST DEBUG:  server process (PID 15736) was terminated
 by
 2010-04-15 22:48:59 EST HINT:  See C include file "ntstatus.h" for a
 2010-04-15 22:48:59 EST LOG:  server process (PID 15736) was terminated by
 2010-04-15 22:48:59 EST LOG:  terminating any other active server
 processes
 2010-04-15 22:48:59 EST DEBUG:  sending SIGQUIT to process 13536
 2010-04-15 22:48:59 EST DEBUG:  sending SIGQUIT to process 14200
 2010-04-15 22:48:59 EST DEBUG:  sending SIGQUIT to process 13948
 2010-04-15 22:48:59 EST LOG:  all server processes terminated;
 reinitializing
 2010-04-15 22:48:59 EST DEBUG:  shmem_exit(0)
 2010-04-15 22:48:59 EST DEBUG:  invoking IpcMemoryCreate(size=36741120)
 2010-04-15 22:49:00 EST FATAL:  pre-existing shared memory block is still
 in
 use
 2010-04-15 22:49:00 EST HINT:  Check if there are any old server processes
 2010-04-15 22:49:00 EST DEBUG:  proc_exit(1)
 2010-04-15 22:49:00 EST DEBUG:  shmem_exit(1)
 2010-04-15 22:49:00 EST DEBUG:  exit(1)
 2010-04-15 22:49:00 EST DEBUG:  logger shutting down
 2010-04-15 22:49:00 EST DEBUG:  proc_exit(0)
 2010-04-15 22:49:00 EST DEBUG:  shmem_exit(0)
 2010-04-15 22:49:00 EST DEBUG:  exit(0)
 UPDATE TO ORIGINAL EMAIL: After some thorough testing over the last days
 on
 this (I have a datafile that I can provide for pg_restore with which to
 reproduce the crash with single index creation statement), it only happens
 on Postgres 8.3, and not with Postgres 8.4.
 This lessens the impact for us, providing a way around it by upgrading to
 8.4, but I would have considered this bug as pretty much the most serious
 kind as it brings down the postmaster entirely forcing complete restart.
 It also seems completely related to new geography types - we've been using
 geometries for a good while.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/506>
