[postgis-devel] St_Intersection on same table
Paragon Corporation lr at pcorp.us
Fri Apr 23 12:48:16 PDT 2010
Rafal,
This question is more appropriate for the PostGIS User's group rather than
the PostGIS developer's group.
To answer your question -- We are suspecting you will want to do a SELF JOIN
accompanied by a ST_Union, ST_Intersection, and/or possibly a
ST_SymDifference.
What is unclear to us is
If you have 3 polygons - lets say 1,2,3
1 intersects with 2
2 intersects with 3 (but not with 1)
What are you expecting to happen here?
A) intersection(1,2)  count 2, Intersection(2,3) count 2
Or
B) You don't allow the same geometry to be counted twice in which case
You throw out the whole thing  return the empty set
Or
C) You arbitrarily pick a set and return intersection (1,2)
D) Similarly we assume if you have a case where 1,2,3 all intersect then you
would return
ST_Intersection(ST_Intersection(1,2),3), count 3 ?
Or
Would you treat as a pairwise intersection
E) 1,2,3 x 1,2, 3 intesection resutling in  3 records with count of 2 each
1,2
2,3
1,3
Leo and Regina
http://www.postgis.us
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Rafal
Foltynski
Sent: Friday, April 23, 2010 11:32 AM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] St_Intersection on same table
I have a table with many overlying polygons.  I want to create a new polygon
relation from the intersection of these polygons that has two fields 1.
geometry of small polygons - the result of St_Intersection() and 2. count of
the number of overlying polygons that each small polygon was created from.
How do I create a query to run St_Intersect on the same geometry field in
one table?
For example: if I have a table with 3 polygons, 2 of them share a small area
and the third polygon is disjoint, the resulting polygon relation would only
have one small polygon area (shared area between two polygons) and count of
2.
Rafal
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
